New to me AC SC Post Hole Auger |
Brad MI
Joined: 12 Sep 2009 Location: Arcadia MI Points: 339 |
Topic: New to me AC SC Post Hole AugerPosted: 03 Jun 2010 at 10:00pm |
Here is what I found buried in the corner of a barn, and what ended up on my trailer..
The arms are just like those that mount on the SC lift arms, with the added SC eye and bail mounting hardware. Does anyone have one like it? The 24" spade was used for cherry tree transplanting. |
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 03 Jun 2010 at 10:23pm |
Brad - man is that a big auger, if it was longer you dig some holes big enough bury a body....LOL! Mike
Edited by Skyhighballoon(MO) - 03 Jun 2010 at 10:38pm |
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Michael Crowe
Joined: 11 Sep 2009 Location: Kansas City Points: 1726 |
Posted: 03 Jun 2010 at 10:41pm |
Mike, I have an identical unit with a 12" auger. They were made by Roper for AC.
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 04 Jun 2010 at 5:54am |
Must have been a project to dig the unit out of that barn! Nice find.
WC, CA, D14, WD45
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 04 Jun 2010 at 6:04am |
If you tried dropping that bit into the ground here in CT, I would bet the tractor would get spun around some quick!, Nice piece.
GlenninPA
Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Posted: 04 Jun 2010 at 6:39am |
Nice Roper digger!
That has to be the biggest auger I have ever seen on one.
I should post a picture of the smallest I have seen, a 6 inch one on mine. Edited by GlenninPA - 04 Jun 2010 at 6:41am |
JCSinPITTS,PA
Posted: 04 Jun 2010 at 7:22am |
I got one last year off of craiglist but it is missing the 1/2 of the pto that snaps on the tractor so i never got to use it, also looking for a manuel, do they really work??? mine has the remains of a handle that someone was suppose to hold I guess to help steady it.
Jim Lindemood
Joined: 22 Sep 2009 Location: Dry Ridge, KY Points: 2569 |
Posted: 04 Jun 2010 at 7:32am |
Nice find. That sucker will make a hole!! If you are planting cherry trees, bet it does the job.
Jim Lindemood
Posted: 04 Jun 2010 at 7:34am |
JC - the handle is used to line up the auger for a straight hole when it is lifted.
Bob(W-Md)
Joined: 12 Sep 2009 Location: Cumberland Md Points: 86 |
Posted: 04 Jun 2010 at 7:48am |
This is the one I have.Yes it does work well.The one you have with the short auger probably would only make about 10 revolutions to get to the its depth for a tree planting in the right soil. Nice Find
JCSinPITTS,PA
Posted: 04 Jun 2010 at 10:19am |
you handle looks really nice and the unit looks nice painted!!!, hopefully after i get 1/2 of pto and drill some holes to know off rust i can paint mine, what for gear oil does it take?
Good
Joined: 05 Apr 2010 Location: Logansport IN Points: 453 |
Posted: 04 Jun 2010 at 10:42am |
My Roper just hooks to the arms not snap coupler it stays pretty strait just back up a little when almost all the way down.You have to get on the tractor from the front though.
Steve(SEMN)
Joined: 12 Sep 2009 Location: Rochester, MN Points: 836 |
Bob's handle is not a roper handle. It is appears to be off a NO. 10 posthole digger.
The Roper handle is a pipe with two holes in it and bolted to the gear box. I have a roper PHD and a No. 10 PHD.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 04 Jun 2010 at 11:45am |
We liked the Danhuser (?) when we sold them and at that time they did have an adapter to mount it on Allis Chalmers tractors. Take a good look at that auger. We mounted a Danhuser on a (don't laugh ) B tractor with that size auger.
The customer was an orchard man and was using it to plant a new section of peach orchard. It worked fine but needless to say it had a ton of weights - sandbags and the like - on the front axle to hold it down and pull it out of the ground.
Great Find. Especially a snap coupler post hole digger. They have to be scarce.
Good Luck!
Bill Long
rossinmich
Joined: 12 Sep 2009 Location: West Michigan Points: 187 |
Posted: 04 Jun 2010 at 3:23pm |
Did you by chance get that off craigslist from a guy up in benzie? |
BILLP-SE-MI
Joined: 13 Sep 2009 Location: SE Michigan Points: 687 |
Posted: 04 Jun 2010 at 6:18pm |
Great find Brad. We used an auger that size that to plant a bunch of trees a work .It was on are 3000 ford. I think we planted about 150 to 200 trees. It sure beats using a shovel.
