New to me 5040
Afmedic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Afmedic Quote  Post ReplyReply Direct Link To This Post Topic: New to me 5040
    Posted: 07 Jun 2018 at 11:07pm
I got a 5040 the other day and I'm trying to figure out how to use it
I ordered the operators manual but it isnt here yet. I've been searching for days and cant find any info info on how to shift this thing! Any insight out there?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 2:53am
Push the clutch down and select the gear if its the 6 speed you have two sets of gear
patterns,you need to center the shifter in neutral to go from one range to the other.I'd
guess you never drove an Oliver or Cockshutt tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Afmedic Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 5:02am
I've never driven an Oliver or cockshutt you are correct. Do you have to push the shifter down or anything fancy or does it truly move like the pattern shows on the cover
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 7:01am
It moves back and forth just like the pattern a little tricky at first but easy once you get
used to it. Once bought a Case 400 from a fellow that had  owned the tractor for 10 years told me it was a great tractor but it was just geared way too high.When I went to load it I shifted it down into the low side he'd never been able to find that set of gears.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 8:05am
Like Gary says, it can be a bit tricky to get it into gear at first......but it gets easier to do the more you use it.
No pushing down is req'd, but I found that the lever needs to be firmly held over to the left when selecting those gears (R1/1st or R2/4th IIRC) in either range.
The mechanism is a bit sloppy.
Better QC or a "template" higher up on the shift lever would have helped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Afmedic Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 9:11am
I sat on it and was able to get it in to all gears. Wow that's sloppy!no way to tighten it up any?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 10:38am
Ted,
Nothing readily apparent for a fix.
I'd thought about making that "template" mentioned above to force the shifting lever into the correct positions, but never got around to it.  (It's been sold)
The PTO engage lever was also a bit sloppy; I made a stop for it.
The PTO clutch (2nd stage) always seemed to drag and it was difficult to engage without some clashing of gear teeth.
All in all, the 5040 was a very stout tractor and the Power Steering was excellent even with a loader.
BTW, if anyone is thinking of putting a block heater in a 5040, I have the part number and source for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Afmedic Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 8:43pm
Is there a good source for steering parts for the 5040? I found 2 websites that sell lots of parts for it, but I cant tine the ball joint at the end of they hydraulic cylinder part on the left side of the tractor. Mine is loose as can be, and I'd like to replace it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 11:05pm
have you tried Import Tractor Parts ?
Is this the part you're looking for?  72091371
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 12:24am
Import Tractor is a very good source for parts also ebay has lots of parts.Its about the same tractor as the Long 445 and Oliver 1265 many parts will interchange between those tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Afmedic Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 4:42am
I have been looking on that site but I cant find that diagram! Number 7 is the one I need. The ball joint in mine is shot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 9:28am
the diagram I posted was from the online AGCO Parts Book
Just click the box to the right of "Guest User"
Then enter 5040.   Click on the 5040 TRACTOR
Scroll down to AXLES, STEERING & WHEELS, STEERING, LINKAGE (page 208)
Item 7 is p/n 72090551 which is further detailed under;
HYDRAULIC SYSTEM - STEERING SYSTEM, CYLINDER (page 226)
This may be a hard thing to find new or if used, in good condition.
The Long tractors may share this same part/assembly.
I've read where Oliver 550s use the same thing. IDK
Edited by Gatz in NE - 09 Jun 2018 at 9:34am
