New to me 200 new here too |
Post Reply |
maggieglide
Bronze Level Joined: 19 Oct 2018 Location: 27530 Points: 8 |
Posted: 19 Oct 2018 at 5:58pm |
Excited to say I finally have bought a 200. My uncle used to have one when we were kids and I always wanted one. I am not a farmer but will use it to mow our property and restore one day. It seems to be in pretty good shape but has a few issues. Needs an alternator and tach cable. I think a few of the injectors are leaking. New seals? Washers? It seems to run well but I hear zero turbo whistle even with a wore out muffler. Anyway, glad to be here.tractor1_2018-10-19_17-56-37.jpgtractor_3.jpg
Orange Level Access Joined: 12 Sep 2009 Points: 19473 |
Injectors don't usually leak. It's the valve cover gasket.
maggieglide
allisorange
Silver Level Joined: 27 Mar 2010 Location: perkins, michig Points: 373 |
Like the Doc said it is valve cover gasket. John Carlson
HD6GTOM
Orange Level Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Mine starts and runs good. I can't here any turbo while inside the cab
Good luck with her. |
Red Bank
Orange Level Access Joined: 18 Apr 2018 Location: Germanton NC Points: 1049 |
Welcome to the forum and post more pics of the tractor. Are you around Goldsboro?
maggieglide
Yes I’m in Goldsboro, you?
Red Bank
North of Winston-Salem I have two 200s
Red Bank
I replaced the alternators on both of my 200s with one wire alternators but after going through matching up the right gears for the tach drive I would recommend getting yours rebuilt if all the parts are there. Is it not charging? Or is it missing the gear drive for the tach cable?
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8135 |
Welcome to the forum. Nice tractor you have
pirlbeck
Silver Level Joined: 01 Dec 2009 Location: West Central IA Points: 221 |
Just be aware that after the valve cover leak is repaired, it may still appear that there is a leak until the oil that leaked from the valve cover quits working it's way out from around the injectors.
Unit3
Orange Level Joined: 17 Oct 2009 Location: NC Iowa Points: 5495 |
The prettiest grill Allis ever made graced the front of 200.
maggieglide
The bearing sounds terrible, where can I find a rebuild kit. I haven’t found one yet.
maggieglide
Thank you!
maggieglide
Thank you |
Phil48ACWC
Silver Level Joined: 17 Jan 2013 Location: Vermont Points: 278 |
Phil48ACWC
https://www.ebay.com/itm/10DN-Delco-alternator-repair-kit-Brushes-Bearings-63-72-Early-Chevy-GM-Pontiac/191810885796?hash=item2ca8d1d8a4:g:KYQAAOSwFNZWybPR:sc:USPSFirstClass!05757!US!-1:rk:1:pf:0&vxp=mtr
Or click above for alternator brushes and bearings only.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7968 |
As stated,folks think they have leaky injectors but it turns out to be cover gasket leaking into injector hole. Try it and see.
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4631 |
X3 on the replacement of the valve cover gasket. My XT was doing the same thing. A good steam cleaning will clean it up if you have one available to rent. Local dealer allows me to use his for $25. Does wonders on all that oil and grease especially with some Purple cleaner soaking for 15 minutes helps also. 200 was a good tractor. Stilll a lot of them in my area.
maggieglide
Thank you for the advice. A heater power washer? I’m sure I could rent one
AC720Man
Steam Jenny is the common name. Too expensive to buy unless you have a large operation with lots of equipment or have a repair business.
Post Reply | |
