New to me 160 |
PollackPete ![]() Bronze Level ![]() Joined: 09 Nov 2020 Location: Stillwater,NY Points: 9 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Jul 2024 at 6:38am |
Just purchased a 1972 or 1973 Allis Chalmers 160.Looking for a rubber shifter boot.Seems kinda hard to find.Need a source for either a new one or suggestions for something that will be close to fitting.Also,is 10w30 motor oil the oil of choice for the tranny and hydraulics? I'm sure I will have more questions as I dig into this tractor.Suppose to have a blown head gasket.Common problem??Thanks for any and all info.
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2876 |
I run Chevron THF in the transmission of my 160. Good little tractors but can be frustrating.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4861 |
Find yourself an operators manual. It will have almost all the information you will ever need.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5072 |
I purchased my shifter boot from SLI in Pa. Close to $100. They tend to tear due to the shift cover fingers being bent down too far. I used a pair of channel locks and gently grabbed each ear and bent them up some. Solved the problem. I use Fram 821 UTF from Carquest in my transmission/hydraulic system. The 160 is a handy 40 hp tractor, some parts are difficult to find but I've been lucky so far. Takes a little more searching than my other AC's due to their low production. The Perkins is great on fuel economy. Foot throttle is very handy and it blows my mind they were not utilized on other models. I had my engine completely rebuilt 2 years ago around 7640 hours due to a blown head gasket. The head was decked and completely rebuilt. New pistons, sleeves, rings, oil pump, cam, and the list goes on and on lol. Money well spent. It starts easy in cold weather. Good luck, I think you will like it once you get it running. Don't just throw a head gasket on it, have the head checked out or your wasting your time and money.
Edited by AC720Man - 09 Jul 2024 at 6:32am |
Thank you AC720Man for the info.Had to look up what SLI meant.Finally found it and got their phone number.Will call tomorrow.Yes,I will not just throw a head gasket on and hope for the best.I will take the head to our local NAPA machine shop to have it checked out.They'll check gasket surface for trueness,check for cracks,probably want to do a valve job.I wont be getting to this project until Winter time.Busy right now.As far as hydro and tranny fluid,I'll probably use the premium fluid from Tractor Supply.I buy LOTS of it for my other 40 plus farm tractors.I'm addicted!
40 plus! Wow, how many are AC’s? Brenda is an incredible parts person. She will help you find what you’re looking for if she doesn’t have it. But she has a lot of items in stock, always amazes me of how many parts she has in stock for these old AC tractors. Is yours a One Sixty or a 160? Early model versus later model.
Only five are Allis Chalmers.Got one WC,three WD,and now the 160.Says 160 on the hood,but one sixty on data plate.Most others in my collection are Ford with a couple Ferguson,Massey Ferguson,Case,David Brown,Oliver,even a Minneapolis Moline and a few Fordson Diesels thrown in.Gotta admit,I really enjoy fooling with old iron.Keeps me out of trouble.At least most of the time!
They both will say One Sixty on the name plate but the early letter tractor One-Sixty had the hydraulic filter down near the hydraulic levers. The 160 filter is in the transmission housing near the right side of the seat. Thats the easiest way to determine which model you have. If the tractor has a repaint some one could have changed the decals so those are a few things to check.
Congratulations, neat tractor Edited by AC720Man - 11 Jul 2024 at 10:26pm |
Mine has the filter to the right of the seat.I guess under the four bolt square plate? The other filter up near the radiator.Must make it a 160,I guess.Checked SLI yesterday.No shifter boots left in captivity.She said she shipped the last one just last week.Going to try and find something else that I can adapt.Got a small boot coming from Amazon that looks like it may work.From a Volkswagen,I guess.
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8501 |
I just noticed you’re just about a neighbor. We’re down near Albany
Yes the filter is under the square plate. Highly recommend removing it and cleaning it. Be gentle with it as it’s made of plastic and are unfortunately NLA. It’s a fine mesh so it does a good job of collecting debris. If it’s dirty that will affect the hydraulic lift arms and remotes. Make sure you keep the fluids at full on the dipstick. That’s the plug that a 3/8’ socket wrench fits in. They are known to get air in the system after oil changes and when cleaning the filter. I install a 4’ hose in a remote and the other end in a clean container. Start the tractor and have someone operate the hydraulic lever back and forth until the air is gone a good stream of oil come out. Repeat for all remotes. Doesn’t take much to clear the system. Operate 3 pt arms to make sure they operate. Shut off the tractor and top of the hydraulic fluid after it sits for 15 minutes and your done.
