New shed
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Topic: New shed
    Posted: 06 Jul 2022 at 4:08pm
Im building a new machine shed to store a WD45, bush hog mower and a D8 Caterpiller at a remote farm. Im not even sure ill be able to get power to it without the power company expecting me to pay for it since there won’t be a house there.
Just going to have a gravel floor. What size gravel is best?
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2022 at 5:30pm
Bigger is better.
estout81 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote estout81 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2022 at 5:43pm
Then cote it with asphalt grindings.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2022 at 5:52pm
I've got 1 inch inside the barn probably 4 inches think, 40x40 parking area behind the barn I put down 3 inch as a base then put about 4 inches of 2 inch on top of that,it's all held up real good,I do have one slab of concrete on one side inside the barn that's 12 foot wide by 20 foot long, a lot easier to work on equipment and find those small nuts,bolts and screws that get dropped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2022 at 5:52pm
My Barn floor was 2" Clean.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 1:58pm
 When I put my driveway in I was told the asphalt grinding should be 4" to 6" thick and it's on top of a layer of limestone like railroad uses and then had it chipped and sealed it's been 15 years and is holding up great.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 4:51pm
I put 10" of class 5 road gravle in my tractor shed. Once it's leveled and your drive over it a few times it gets hard and stays in place. I lik having gravel in my tractor shed. All my tractors leak something.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 5:37pm
If you use gravel, spreading calcium chloride on it will really harden it up. Personally, I would put coarser gravel in the bottom, with crushed gravel (3/4" and minus) on top. It makes it easier to walk on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 5:59pm
the "crushed rock" around here is limestone... You get 2-3 inch "rock" to put down as a base... then you put a few inches of 1" and smaller that has a lot of "FINES" or dust in it... when you water that down and compact it, it turns HARD on top and is more like concrete..
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 6:54pm
i've used just normal road gravel, sure is nicer to lay on than rock or larger gravel, but some will stick to you unless you lay some old carpet or a rug down first. it's nice like Dave said...something always leaks!
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 7:30pm
On a rented farm they had a slant wall bldg that floor had 3 - 4" of limestone like what is used on county roads and State Hiway shoulders in west central Iowa. Think it's called D stone, is 3/4" crushed limestone down to dust. It worked good, water off equipment drained away, rodents didn't dig, mud unless big clods coming off equip got worked into it. It's still there owned by same family, bldg was built in 1972.
This page was generated in 0.979 seconds.
