New replacement seat for my HD5
rwhendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwhendrix Quote  Post ReplyReply Direct Link To This Post Topic: New replacement seat for my HD5
    Posted: 23 Jan 2014 at 12:58pm
Hi,
Im looking for a source to replace my missing seat and armrest cushions on my HD5 dozer. Any suggestions. Ive looked around some on the internet. Dont look like anyone is making exact replacements for it anywhere. I had some good luck finding new seat and back for my International 300 utility tractor last year. Are Allis dozer seats harder to find? It is looking that way.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2014 at 3:35pm
About like hens teeth .
I made my own the first time around - built a plywood box , then covered it with vinyl cover on top of 4" of foam , same for arm rests box, foam and vinyl.
 Next i used a bucket seat from Chev Blazer for quite a few years as I found that 4" rise fit me I kept the height by building a mount to keep height above the under seat tool storage area.
 Now have a after market suspension seat - found I seldom used the arm rests above battery boxes so just have steel plate covering them now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2014 at 7:55pm
Just went thru this on my HD7G, went to a local upholsterer with a photo of the parts manual and the original style seat bottom, we built up from a plywood base to a full 7 1/2' thick multi stage stiffness cushion and wrapped it in exterior grade vinyl. Cost me almost $200 but fit like original and sits fine while working.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2014 at 10:40pm
There is cheap but functional,or first class but kind of pricey.Cheap is get plywood for bases, foam from old couches or old mattress,cover with vinyl fold corner like raping a package and staple to plywood.First class sewed seams like in the day John Hahn tractor seats from Craigmont ID.
208 924 5538
www.hahn-tractor-seat.com
Sorry I don't know how to run this thing to make a link.
Ray
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 1:44am
I did the same as Coke..built my own...was real easy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwhendrix Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 6:03am
Well im not rolling in spare cash, so I like the idea of making my own. when the weather here warms up I will see what I can come up with. Thanks for the ideas.
Pipeline Badger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipeline Badger Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2014 at 7:44am
I need to do this also. I have been using a old boat cushion for to long. But hey it matches the boat cushion on the seat of my TL 20 and on my MM Z tractor.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2014 at 2:04pm
I've bought cushions for my Allis stuff from Speer Cushion- www.speercushion.com
derekhopkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote derekhopkins Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2014 at 2:02am
I found cheapest seat fix was to cut out a couple of pieces of 5 ply and two for battery covers then get local upholster guy to cover with foam and some canvass. Worked really well and easy to remove when cleaning machine.
Edited by derekhopkins - 31 Jan 2014 at 2:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwhendrix Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2014 at 6:21am
Thanks for all the suggestions everyone. I will be working on this as the weather warms up here some. I will try to let you know how it turns out.
