new owner looking for help/knowledge |
acep
Topic: new owner looking for help/knowledgePosted: 19 Jun 2010 at 10:58pm |
i recently aquired a 1950 allis chalmers b, and since i know absolutely nothing about tractors i would like some guidence. i would like to know if it has a 3pt hitch, or what to look for so i can get a brush hog and maybe something to push snow. it has a pto, but no hydraulic lines. it has a single plow with a disc that is lowered by a hand lever tilt and depth levers. i know this is a lot to ask for but it would be greatly apprieciated. thank you to anyone willing to help.
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 19 Jun 2010 at 11:56pm |
gots a pic?
Bee
Posted: 20 Jun 2010 at 1:38am |
New here with a B also. This is what the factory Hydraulic looks like. Has a pump on left rear of PTO- (first picture)
Second picture shows after market hydraulic pump added to run off fan belt. PTO is after market. Have seen them (3pt hitch) selling from @380$ - to 600$. Pump almost looks like a power steering assembly. ![]()
Bob, North Carolina
1949 B |
Bee
Posted: 20 Jun 2010 at 1:40am |
Here is pic of aftermarket 3 pt.
Bob, North Carolina
1949 B |
bluebanshee
Posted: 20 Jun 2010 at 2:00am |
Most likely your PTO is the smaller (1-1/8") size and won't work with PTO driven implements unless you get an adapter. These tractors really aren't ideal for brushhogging compared to newer tractors with better hydraulic setups. PTO/hydro pump stops when the clutch is in.
We built a heavy duty 3 pt for ours, with a large cylinder like the one pictured above and the tractors high pressure pump the lift capacity is more than you could use without breaking stuff. I can post pictures if you wanted. Edited by bluebanshee - 20 Jun 2010 at 2:02am |
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 20 Jun 2010 at 5:25am |
ACEP, my first suggestion would be to buy an Operator's Manual for your tractor. Some of the sponsors of this website offer them. After you read it, you'll have lots of questions which the folks on here will be happy to answer for you! Congratulations on your B - neat little tractor. Hope you have fun with it.
WC, CA, D14, WD45
CTuckerNWIL
Posted: 20 Jun 2010 at 6:18am |
Bee's first picture shows lift arms for a Snap Couple set up which very few B's had. Many people have added 3pt to their B's with the original hydraulic pump as the power source. Most have found the front of the tractor to be light and need weight to pick up a bush hog mower but adding weight up front makes this possible.
The hand lift and plow might be as valuable to a collector as the 3pt would be to you. Take a picture of the back, right side of the PTO and post it here or email to me and I will post it. Then we can see what you have and what you will need to change. Charlie email is 1954w45@gmail.com |
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 20 Jun 2010 at 6:33am |
First, Welcome to the Unofficial Allis Chalmers site. You will find volumes of information on what you need here. People are and will continue to be most helpful. Remember, they don't make Allis Chalmers any more. We have to do all we can to keep the name alive. I am delighted to see that you have acquired my favorate Allis Chalmers Unit. It does not have a three point hitch, and as said above attaching a lift and hyd that will lift a bush hog type mower can make the front very light. Many on this site use Woods under belly mowers for their lawn. However if you are looking for a rather heavy duty rotary mower you may want to look for a pull behind. Be certain to check out an overruning clutch. The rotary mower with the flywheel effect will have a tendance to keep your tractor moving after you have depressed the clutch.Hyd systems can be obtained for what you have but send us pictures so that we can see just what you need.
In the meantime please be advised that you have obtained a very dependable well known tractor. Let me again welcome you to the site and wish you the best of luck.
Good Luck!
Bill Long
ps: I don't own any tractors. This is a picture of me and my son at Union Bridge WI GOTO
acep
Posted: 20 Jun 2010 at 11:28am |
wallace
acep
Posted: 20 Jun 2010 at 11:29am |
wallace
acep
Posted: 20 Jun 2010 at 11:32am |
wallace
acep
Posted: 20 Jun 2010 at 11:33am |
these are what i guess the pics that u guys requested i hope i did not skew it too much
wallace
CTuckerNWIL
Posted: 20 Jun 2010 at 11:48am |
It looks like you would need the hydraulic pump. If your tractor has the cam for it, it would be a simple bolt on change.
acep
Posted: 20 Jun 2010 at 12:18pm |
thank you very much cTucker i appreciate your help. ive searched the web for extra info do you have a suggestion on a site to visit?
wallace
bluebanshee
Posted: 20 Jun 2010 at 12:58pm |
What about the possibility of his tractor being an earlier B than what he is told? Were the pumps not standard equipment on later models?
CTuckerNWIL
Posted: 20 Jun 2010 at 1:24pm |
Blue brings up a good point, what is the serial number next to the shifter? Anything you want to know about this tractor you can find here on this site. Darins web store has manuals(top of the page click Allis Store) to help fix things and if you want a part for your tractor ,ask on here first and then try ebay.
Bob-Maine
Joined: 11 Sep 2009 Location: Central Maine Points: 922 |
Posted: 20 Jun 2010 at 1:41pm |
acep, If you do wind up using a bush hog on this tractor, don't get one over 4' wide and be sure to get an overriding clutch to go on the PTO shaft. Tractors without live PTO can be pushed into a rock wall or a tree by the inertia of the bush hog even after you push the clutch. The overriding clutch helps prevent that. Bob@allisdowneast
JimD
Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
Posted: 20 Jun 2010 at 4:27pm |
To the right of your PTo shaft is where the pump goes. I can't be sure, but it looks like you have the PTO assembly that cannot have the pump bolted on. If there is a large ROUND plate there, you will have to change the entire PTO assembly. IF the cover has 3 bolts, and 1 stud with a nut, then a pump can be added reasonably.
We have the pumps, and the hitches. Feel free to call my toll free number 877-378-6543 tomorrow and I will be happy to walk you through any questions. I expect the phone to be busy though, as I have been gone for a week.
JIm Danforth
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543 |
acep
Posted: 20 Jun 2010 at 7:24pm |
thanks guys, i have to be honest i kinda expected to be pushed aside because of my lack experience. but u guys have been very helpfull. yes it has a round plate on the right side of the pto. and the serial # reads B31918 or like it says right above it, tractor no
wallace
Jacob (WI,ND)
Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1249 |
Posted: 20 Jun 2010 at 7:57pm |
Looks like you have a 1939 according to the serial number (tractor number) you give.
(unless you forgot a number?) Easy to do with years of paint and crud. You are right, this is the best AC site you will find, the guys (and gals) here are always more than willing to help, and you will always eventually get an answer. As others have suggested, get yourself a manual, it will help a lot! Also, you can locate the engine casting number, and using this site: you can confirm what year tractor you have. This is a way to see if your engine block is original to the tractor, or to see approximately what year your tractor is if there is no tractor number (like if the transmission was replaced at some point in its life) or if parts have been swapped out over time. If the tractor number you give is correct, and its a 1939 your engine casting number should be AM 2916-11 You can do the same test with the engine serial number (not the casting number, which it different) which is located on the rear flange of the engine, where it bolts to the torque tube. And BTW, check out Bryan's site http://people.clemson.edu/~wsmth/index.htm some more, he has some useful stuff there. Welcome, and keep us posted on your progress!
Edited by Jacob (WI,ND) - 20 Jun 2010 at 8:12pm |
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
acep
Posted: 20 Jun 2010 at 8:15pm |
jacob thanks and yes you are right the casting number on the block is AM2916-11
wallace
acep
Posted: 20 Jun 2010 at 8:24pm |
which manuals do any of you recommend? my skill level for repairs would be catoragized as advanced, if i can incorporate automobiles and trains into the equation.
wallace
JimD
Posted: 20 Jun 2010 at 8:28pm |
There are 2 that will serve you well. A parts manual will have a diagramof every part on the tractor. Very handy. The second is a factory service manual. There is also an I&T brand manual, and we sell a lot of them, but by far, I prefer the Factory service manual. It will provide complete tear-down and rebuild, plus all torque specs etc.
JimD
acep
Posted: 20 Jun 2010 at 8:47pm |
ok jimd do u mean ur reproduction manuals?
wallace
JimD
Posted: 20 Jun 2010 at 8:51pm |
Yes. If you can find originals, they are very expensive (usually). They are reproductions of exactly what the mechanic would have had if you went to an AC dealer.
JimD
