New one on me
Les Royer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Topic: New one on me
    Posted: 12 Aug 2018 at 8:00pm
I'm about to go out and install points and condenser on a flathead V8 motor. I jave no idea what I.m doing. And I have installed points before. Do a poll to see if'n I get it stated before midnight?
I still gots my A/C but it's clear out in the barn now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 8:04pm
which midnight, there's several of them !!
sad thing is I tossed a good block away 4-5 years ago , NO interest in this part of the world for it. Still have a water pump and genny though..found them yesterday..forgot what I WAS looking for, gee, getting old is fun....
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 9:27pm
 Well,,Les,,I ain't ever worked on them ford flatheads but,,,but,,,,I think they are the cutiest engines ever,,, I like the twin water pumps per bank,,,,,Clap
 Now,,,without gettin my pokin stickm out ,,,,I'd say at least a couple of days,,,,ole Shameless tells me you tend to get side tracked is why,,,,,,Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 9:55pm
i'm thunk'in that there was someone on here that had one of them morfidite engines in a ferd tractor he posted one day. maybe he'll pipe up and hep ya!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 6:57am
If you've installed them before, how can you say you don't know what you're doing?? Clap  Putting in points is like drillin a well,,,,,,,,once you've done it, it's EASY the next time.  All you need is a screw driver, dwell meter or feeler gauge and a timing light.  BINGO, you're all set!
BUT, I'm betting you didn't get it running by midnight.  You ONLY had 3 hours to 'git er done'. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 12:41pm
I took one look at that thing, took the side caps off and the ignition coil, and walked away with my head shaking. And I havent been back. I'm thinking I might check the point gap and call it good cause to change out those points, it looks like it would be best to just pull the distributor and do it on a werk bench.
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 1:29pm
Is it the early style with the distributor in the front of the engine behind the fan?
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 3:42pm
That early style with the distributor driven off the end of the camshaft at the front of the engine was a real PIA. You really couldn't see what you were doing and needed to prop a mirror down between the fan and rad to work on it. It seems to me as if there where two sets of points as well, one for each bank of cylinders. Old Henry more or less developed the concept of that V8 by merging two Model A 4 cylinder engines which resulted in two water pumps and two sets of points. I think that the fan was mounted on the generator.
allis g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 7:30pm
What is that FH in? I have a 51 Mercury I'm restoring great aunt bought it brand new from Coberly Ford, have the original sales receipt hand written paid 2300$ for it got 50$ for her old car, extras were heater, radio, fender skirts and outside rear mirror. she put 200$ down.  It has 89k miles on it.  She should have stopped driving long before she did. Thats why its being restored.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 7:44pm
Couple different distributors used on the 32 to 48 ford - then later changed again
Early used the Ball type - with coil on top and 2 caps on side -
 To put points in - remove the distributor from engine - then work on it on bench
Late type Crab has a flat cap with col mounted off to side so little easier to work on but removing it also works better .
 Seems I did a lot of them way back - only thing to be sure of is to INDEX into cam as the drive lug has to fit into slot on end of cam - if not careful you will crack housing when tightening down the 2 bolts .
