New Mig Cart,,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2023 at 6:40pm
Joe, if you look close at the drawing, you see the SWITCH is between the BOARD and the MOTOR... That means the SWITCH has to be CLOSED for the motor to run........ It still looks like the SWITCH is sticking, to me......
or like Dave said, the WIRE is sticking inside the sheath / rollers and jumping... making it look like it is still feeding with no power.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2023 at 6:46pm
   Well,,,I had typed up a long winded dis-a-tation of the latest on my current project AND instead of clicking "Post Reply" ,,,I must of clicked on something else and sent that post to TimBuckToo,,,!!  Dang,,I HATE when that CHIT
 happens,,!!
 Now,,I know some must be sittin on pins waiting to find out how that poor Lincoln fared today,,,,,WinkWink
 After an all day slugfest,,,Wink,,the Lincoln will not have to be escorted to the junk pile,,!!
  I removed the gear drive/Motor and pulled the drive cover as the motor mount bolts are inside the drive. Everything inside looked good with no teeth missing or broken. On a whim, I used a jumper wire and tried the motor and the frigging thing started to run as fast as it always did,,!! I cleaned and repacked the drive and reassembled the Drive/Motor. in it's place.
 Lashed everything up and the motor now runs as fast as before,,!!!????
Only'ist thing I can figure is the trigger contacts on the  "NEW" whip must of had some trash ,,,?? on the contacts,,,,and guess what??? on opening the trigger ,,,I find where some idiot had smeared some heavy grease on the contacts,,,,WTH,,,?
   I HAVE A WELDER,,,,AGAIN,,,!!!
 MANY, MANY THANKS to everyone that volunteered their suggesstions,,,I appreciate all of Ya'll,,,,!!!!ClapClapClapClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2023 at 7:05pm
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2023 at 7:22pm
Good job Joe. Glad you stuck with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 6:41pm
  Well,,after a few false starts,,I finally finished the mig Dolly Cart and I really like it much better than the 4 wheel model I had before.  For main thing,,,I wanted a LOW center of gravity for use on areas with out concrete. The Dolly frame just lends itself to being able to maneuver it many wonderfuls,,!!
 Many THANKS to Steve(ill)  for his design,,,it worked out great!!
 I might of fudged a bit in that I robbed two of the pneumatic tires from the old cart just to give em a tryWinkWink ( Thanks DIYDAVE) still have the hard rubber ones of these don't work out. I was kinda concerned about the weight of the CO2 cylinder shifting around so I put a 3 1/2" muffler clanp  under the plastic handle and bolted her down,,,it ain't gonna move for chit,,,,!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2023 at 9:16am
WELL THANKS JOE !!!! .... Now every time i go to a NEW PAGE on the computer there is a SALE ADD at the top or bottom that wants me to buy a 2 wheel cart, wire feed welder, welding gloves, or a mask !!! .................SOMEBODY is WATCHING !!!  Big smile  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2023 at 6:46pm
 Well,,,Steve,,,,I'm glad you understand,,,every one of them abc agencies know all about me and my shenanigans so ,,,I don't even worry about that any more,,they are gonna do what they do regardless if I like it or not,,,,LOLLOL
 By the way,,,here's another shot of the "STEVE CLONE",,,,ClapClapClap
 I'm sure proud of it,,,!!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2023 at 8:42pm
Looks sharp, Joe!!
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2023 at 2:38am
Wow Joe, that cart looks great, between you and Steve you guys could go into fabrication, looks better, stronger and more practical than anything you could pull off a shelf anywhere. Let me know when you start taking orders. Side note, have you heard anything more from Shameless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2023 at 8:07am
 Actually DirtFarmer,,ole Shameless told me he was gonna go see his Dr on Monday PM and would let me know,,,later.
 I'll give him a hollar after he has time to work the kinks out,,,,,,
 Thanks for asking,,,Clap
