New member needs some advice |
Jim liddle
Joined: 29 Oct 2017 Location: Lebanon, Tn Points: 8 |
Topic: New member needs some advicePosted: 02 Nov 2017 at 8:08pm |
I am new to the forum and I just bought a HD4 with hopes of bringing it back life. The dozer is in decent
Shape but, the engine is rusted and full of water. It also has a place on the block that has weld/brazing and some Epoxy that was leaking. So I am not sure if it is even rebuildable. What are Re powering options if any? Could a 2-71 Detroit be made to work in a HD 4 ? Thanks Jim |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 03 Nov 2017 at 12:12am |
Jim,
Welcome and good luck with the repairs. Some pictures will help folks to understand and magnitude of your project. I cant help you on the repower options but folks like ACmel should be able to. Regards, Chris |
rickv57
Posted: 03 Nov 2017 at 6:43am |
Might possibly have a good running used engine for your hd4, Rick
pinball
Joined: 28 May 2014 Location: missouriu Points: 6458 |
Posted: 03 Nov 2017 at 7:05am |
Hello Jim. Welcome to the forum. I have a h4 crawler with a gas motor. MY thoughts are what else is wrong with your machine. I would imagine you might be able to find a motor. Gas would be cheaper. Mine has plenty of power in 1st gear. Machines that are in decent shape that works fine don't really bring a lot of money. Parts can be very expensive as a lot of them were scrapped out when junkyard metal got so hi and the ones in the salvage yards they are very proud of. I don't know if there the same but when I go to the local dealer for parts for my motor he looks it up and it apparently has the same things I needed but were cross reference to a allis 190. Don't know if it will inter change or not. Maybe some others can tell you. What ever you do I wish you good luck and you will find there are a couple fellows on here that are very knowledgable on the h4
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 03 Nov 2017 at 7:58am |
I don't have any experience with an H4 but im pretty sure it shares parts with a D15 not a 190. after rereading the original post stating HD4, I see what you meant. yes motor parts, basically 2 cylinders knocked off a 301 for the HD4 4 cylinder motor.
Edited by CAL(KS) - 03 Nov 2017 at 9:35am |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42263 |
Posted: 04 Nov 2017 at 8:39am |
AC 2200 engine - basic block and such are gas or diesel - then equipped to be powered by whichever fuel - engine was also used in cotton pickers and some other applications .
One thing if undercarriage or tracks are bad - you have unobtanium parts or lot of hope and pray you can find what you need . Check for slop in rear axle shaft as side bearings in case is another weak spot . |
