New member needs some advice
Jim liddle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim liddle Quote  Post ReplyReply Direct Link To This Post Topic: New member needs some advice
    Posted: 02 Nov 2017 at 8:08pm
I am new to the forum and I just bought a HD4 with hopes of bringing it back life. The dozer is in decent
Shape but, the engine is rusted and full of water. It also has a place on the block that has weld/brazing and some
Epoxy that was leaking. So I am not sure if it is even rebuildable. What are
Re powering options if any? Could a
2-71 Detroit be made to work in a HD 4 ?
Thanks Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 12:12am
Jim,
Welcome and good luck with the repairs.
Some pictures will help folks to understand and magnitude of your project.
I cant help you on the repower options but folks like ACmel should be able to.
rickv57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickv57 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 6:43am
Might possibly have a good running used engine for your hd4, Rick
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 7:05am
Hello Jim. Welcome to the forum. I have a h4 crawler with a gas motor. MY thoughts are what else is wrong with your machine. I would imagine you might be able to find a motor. Gas would be cheaper. Mine has plenty of power in 1st gear. Machines that are in decent shape that works fine don't really bring a lot of money. Parts can be very expensive as a lot of them were scrapped out when junkyard metal got so hi and the ones in the salvage yards they are very proud of. I don't know if there the same but when I go to the local dealer for parts for my motor he looks it up and it apparently has the same things I needed but were cross reference to a allis 190. Don't know if it will inter change or not. Maybe some others can tell you. What ever you do I wish you good luck and you will find there are a couple fellows on here that are very knowledgable on the h4
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 7:58am
I don't have any experience with an H4 but im pretty sure it shares parts with  a D15  not a 190.
after rereading the original post stating HD4, I see what you meant.  yes motor parts, basically 2 cylinders knocked off a 301 for the HD4 4 cylinder motor.Big smile
Edited by CAL(KS) - 03 Nov 2017 at 9:35am
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2017 at 8:39am
AC 2200 engine - basic block and such are gas or diesel - then equipped to be powered by whichever fuel - engine was also used in cotton pickers and some other applications .
 One thing if undercarriage or tracks are bad - you have unobtanium parts or lot of hope and pray you can find  what you need .
 Check for slop in rear axle shaft as side bearings in case is another weak spot .
