New member needs help with M-100 |
Legdoc
Topic: New member needs help with M-100Posted: 26 Feb 2025 at 7:11pm |
Newbie from S. Texas here. I have a M-100 grader and need shifter boots which I can't seem to be able to source or match up. Also what fluid should I fill the transmission with?
Please help. Thank you in advance.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5910 |
Posted: 26 Feb 2025 at 7:52pm |
Link to pictures of Allis M100 Grader just for reference: G https://www.machinerytrader.com/listings/auction-results/allis-chalmers/m100/motor-graders/1048?srsltid=AfmBOopZuSzgSckZ_FiKbhGUJ-1N4b5Gk5iz3F4boLH7iolnx4_POjW4 Link to TractorData Specs https://www.google.com/search?q=tractordata+allis+m100+grader&sca_esv=4b1e09beaa1370b6&sxsrf=AHTn8zrdjdx6kXoZWrHAYLje3Q1BwjPGsQ%3A1740621197729&source=hp&ei=jcW_Z77LKqnep84PqdD6oAk&iflsig=ACkRmUkAAAAAZ7_TnTP4EWhl3uNk8MD9pOaa0jWUuu_N&oq=Tractordata+Allis+M100&gs_lp=Egdnd3Mtd2l6IhZUcmFjdG9yZGF0YSBBbGxpcyBNMTAwKgIIADIFECEYoAFI-MIBUABY5J4BcAB4AJABAJgB0wKgAYcfqgEIMS4xMy41LjO4AQHIAQD4AQGYAhagAtQfwgIEECMYJ8ICCxAAGIAEGJECGIoFwgILEAAYgAQYsQMYgwHCAg4QLhiABBixAxjRAxjHAcICBRAuGIAEwgIREC4YgAQYsQMY0QMYgwEYxwHCAggQABiABBixA8ICCxAuGIAEGLEDGIMBwgIQEAAYgAQYsQMYQxiDARiKBcICChAAGIAEGEMYigXCAgoQLhiABBhDGIoFwgIMEAAYgAQYQxiKBRgKwgITEAAYgAQYkQIYsQMYgwEYigUYCsICDRAAGIAEGLEDGEMYigXCAggQABiABBiSA8ICDhAAGIAEGJECGLEDGIoFwgIREAAYgAQYkQIYsQMYgwEYigXCAgoQABiABBgUGIcCwgIFEAAYgATCAgYQABgWGB7CAgUQIRirApgDAJIHCDAuMTQuNS4zoAfKwwE&sclient=gws-wiz Edited by Gary - 26 Feb 2025 at 7:55pm |
Mikez
Posted: 26 Feb 2025 at 8:04pm |
Can’t help with your question.
But welcome to the forum
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 27 Feb 2025 at 12:02pm |
I used the rubber boots from the axle boots from a front wheel drive car.
wjohn
Posted: 27 Feb 2025 at 9:14pm |
This is probably your best option - sometimes a random part number will surprise you and it's still available new from somewhere, but a lot of the parts for AC construction equipment are no longer available.
Legdoc
Posted: 05 Mar 2025 at 9:17pm |
I appreciate the advice. I went to a CV boot sizing chart and found a semi universal boot for a '96 Acura that is trimmable that will work well. TDH fluid will work.
Thank you again!
