New idea on connecting rods |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: New idea on connecting rodsPosted: 07 Dec 2022 at 11:22am |
Sounds like a neat idea, who will be the first to put one is a pulling motor? 20-30% increase in torq! https://www.roadandtrack.com/news/a41777886/two-piece-connecting-rod-sema/
Charlie
bsallis180
Joined: 29 Jul 2013 Location: Pennsylvania Points: 209 |
Posted: 08 Dec 2022 at 4:50am |
I don’t see where this will benefit in any way but lining someone else’s pocket.
Posted: 10 Dec 2022 at 6:33am |
Looks to me like a new long/tall piston design is in order, instead of a two piece conn rod. All they are doing is drastically lowering the piston pin location using an existing piston forging. Side loads on crank and piston will be increased a bunch !!
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Posted: 10 Dec 2022 at 9:16am |
NEVER green
Posted: 10 Dec 2022 at 9:32am |
Your link was blurred out unless I become a Road and Trick member, I did not.
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11873 |
Posted: 10 Dec 2022 at 11:40am |
Claims that it decreases sidewall pressure are erroneous.
You could do the same thing by just using a shorter rod and a taller piston, although skirt clearance with the crank counterweights are an issue. |
BrianC
Posted: 10 Dec 2022 at 5:51pm |
I was using Firefox and the information was there, on google, yes, blurred out.
Found this site with more information (works in Google browser): |
MACK
Posted: 16 Dec 2022 at 8:51pm |
Should be more HP do to angel of rod to crankshaft,but hard on parts. That is same principle M&W used to gane HP with off set wrist pin. A lot more ware on crank. Most needed crank reground when it came time for overhaul. MACK
Phil48ACWC
Posted: 03 Jan 2023 at 5:39am |
Looks and sounds like total BS to me. I agree with TramwayGuy.
Edited by Phil48ACWC - 03 Jan 2023 at 5:41am |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8989 |
Posted: 03 Jan 2023 at 8:12am |
I'm old and behind the times. Last played with SB Chevys 40+ years ago. Looked at LS engine stripped down on engine stand getting new cam installed. If I remember right,you have to pull heads to do this. Bright idea GM. Any way,I was surprised how short the pistons are. Not much skirt to begin with. Doesn't look like long term design but apparently they run lots of miles and stay together.
Phil48ACWC
Posted: 04 Jan 2023 at 6:54am |
The topic is these new fangled Connecting Rods which don't look like an advantage to me. Nonetheless, answering last post, a cam change can be done on an L series V8 without cylinder head removal. Click on below:
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25274 |
Posted: 09 Jan 2023 at 9:28am |
from their own mouth.... The two-piece con rods are heavier than standard items, creating
additional inertial forces that will increase substantially as the
engine revs faster, so there's a good chance that even if there are
low-end gains, they might come at the expense of high-RPM horsepower. seems you CAN'T get something for nothing, it's a give and take 'upgrade'
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 09 Jan 2023 at 9:03pm |
Doc and Tramway are spot-on. This piece of alumanure is only doing two things- changing the piston height, and reducing the rod length. If you want a piston to last long and not scrub hell out of the cylinder walls, you don't relocate the 'gudeon pin' to a point BELOW THE SKIRT. If you want an engine to be efficient in it's generation of power, you keep the rod length LONG, so the included angle of rod doesn't result in high sideloading of the piston in the hole. The rod length and stroke has other added circumstances, one of which is piston SPEED, and the other is piston ACCELLERATION. Shortening the rod forces the piston's peak velocity (at 90ATDC) UP, which has an inherent problem with combustion pressures- in order for the piston to accellerate fast, the combustion pressure needs to rise extremely fast, JUST to keep up. The result being, the Brake Effective Pressure hasn't changed with respect to measurement just past TDC, but the Brake Effective Pressure is dropping RAPIDLY after 45 degrees, because the piston's accelleration means cylinder VOLUME is rising faster than combustion pressure can keep up. Charles Fayette Taylor covered it in several chapters of his book The Internal Combustion engine in Theory and Practice and Gordon Jennings followed on with it (in my opinion, a bit better) in his 2-Stroke Tuner's Handbook And Gordon's description in many ways stresses greater importance, because a ported 2-stroke is ultimately limited on it's power-stroke duration by the presence of that exhaust port... he's of the 'squish-bander' genre, and had an incredible grasp for not only the timing of that expansion pulse, but he was really sensitive to flame-speed issues, because the 2 stroke's flame velocity was affected by presence of oil in the fuel. Really, the idea of this idea is total horseradish... it baffles me that they'd make such a blatantly false statement. Next up, the earth is a perfect cube, right? |
Phil48ACWC
Posted: 15 Jan 2023 at 8:17am |
X2 what DaveKamp Says!
