New house electrical question |
Page <12 |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 04 Feb 2019 at 4:35pm |
Should work fine, how far have to run and any severe rock in the soil? Under NEC code also needs to be at least 24" down.
JimD
Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
Posted: 04 Feb 2019 at 5:35pm |
Do not need to bury, this will be interior run.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543 |
JimD
It's just a lot cheaper than copper 3/0.
allis g
Joined: 10 Jan 2012 Location: Templeton Points: 415 |
Posted: 05 Feb 2019 at 12:48am |
That looks like aluminum can’t
’ Use it in Calif I wouldn’t anyhow too high fire risk. It expands and contracts too much. |
shameless dude
Posted: 05 Feb 2019 at 2:01am |
I spose running an extension cord is outta the question huh? lol
DMiller
Posted: 05 Feb 2019 at 1:11pm |
All the local electrical contractors use is Aluminum Tri Plex for high amp runs. My own home as are 90% are is fed from the meter base to the breaker panel with same. Not so much a concern for heat and fire probabilities as the old 12/2 w/grd house wire.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3131 |
Posted: 05 Feb 2019 at 1:28pm |
The boxes aren't "Big" to hold a bunch of breakers. The boxes are big to have plenty of room to route those big 4/0 service feed cable and maintain proper bend radius.
Depending on code in your state, you may have to run a 4-wire for your house. In Indiana, all grounds have to run back to the main disconnect.
Joined: 11 Sep 2009 Location: illinois Points: 90804 |
Posted: 05 Feb 2019 at 4:37pm |
4/0 AL cable is good for 205 amps ......... the ground wire 2/0 is good for about 150 amps.... that should be fine for entrance cable. I have had similar in my house for 40 years.
Ryanlark
Posted: 08 May 2021 at 7:35am |
Maybe you should hire a professional electrical company? I am kind of afraid of stuff like this to do it on my own, and it’s better to be safe than sorry. I just learned that from my own mistake. When I moved to my new house, in the beginning everything was perfect. I hired a professional moving company https://texasmovingusa.com/ to help me with everything. After I settled in, I noticed there is a problem with the kitchen switch. I tried to fix it on my own, but the problem was way complicated then I knew. I ended up hurting myself pretty bad, and even made the switch problem worse. So, know I just hire people to help me.
Edited by Ryanlark - 11 May 2021 at 5:16am |
Posted: 08 May 2021 at 8:48am |
After 2 years....i HOPE he already has it installed !!
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 08 May 2021 at 9:23am |
Me too!
Regards, Chris
Page <12 |
