New Guy needs help Allis wd crank/cam issue
vanscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vanscott Quote  Post ReplyReply Direct Link To This Post Topic: New Guy needs help Allis wd crank/cam issue
    Posted: 30 Aug 2011 at 6:43pm
Hello to all--I've watched all you guys for a few months and have been helped quite a bit by all the knowledge you pass on to each other and to those of us just learning--My question relates to my WD--1952 --
My uncle showed up for sunday dinner and brought a crank shaft and a camshaft which he thinks came off a wd-45----and thought I might be able to use them in my WD to gain a little more power---
My problem is that he is 92 and sometimes his memory is not as good as it used to be--(I think mine is getting that way too) but--the casting numbers are--for the crankshaft--226531///for the camshaft--232533----
I have been unable to find either of these numbers in my "reprinted" wd parts book---
Any ideas on where to find out what these parts are off and whether they might work with my wd???
Any thoughts will be welcome--------
jw
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 6:53pm
 I've seen several of the 226531 crankshafts in WD45's and they are the 4 1/2" stroke. I've also had several folks say that they couldn't find that particular number in the book. Maybe that number is from a combine or something,but they are in WD45's for sure.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote vanscott Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 7:02pm
Thanks for the reply-----I'm a little afraid these parts might be from a d-17---I've heard that although the d17 crank will fit ,there is an issue concerning the thrust bearning(center vs front)--but I havent found anyone in my area that seems to know about it-----
Thanks again   jw
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 7:12pm
  wd cranks have the front thrust    d-17 can have a center thrust[bearings]
Post Options Post Options   Thanks (0) Thanks(0)   Quote vanscott Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 7:58pm
I guess I'llstill need to see if the parts I have are wd 45 or d17----
    jw
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 11:00pm
I don't have the numbers but the mains are a fair bit larger dia on D17's.Won't begin to fit the other blocks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vanscott Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 8:26am
Thanks    --------
Looks like it's time to get out the micrometer---
jw
