New Gleaner Side Panels Material, and Speech Ideas
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 6:21pm
Originally posted by cwhit cwhit wrote:
CrestonM, AGCO needs more people like you. Nice job.
Thanks! That means a lot, especially coming from somebody other than my parents. Lol
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 6:40pm
Sorry I didn't get in soon enough, Creston-
One thing you may have been able to look up, is the quantity of insurance clames on burned up combines, and compared the numbers.
I believe you'd find that combine harvesters that use more plastic covers, wear surfaces, etc., will appear in the category which is found burned up more often... and here are the two reasons I suspect to be the most at fault:
First: Molded plastic parts can be made into wonderful shapes, but to preserve rigidity, they must be molded with substantially more convoluted shapes- additional planes and edges. These planes and edges provide more places for dust, dirt, and chaff to accumulate, and eventually, ignite... and once burning, the plastics become an aggressive accellerant.
Second: Plastic guideways provide wonderful wear-resistance and reduce plant damage, but serve as excellent dielectric surfaces for creating static electricity. Galvanized steel, while not as 'nice' in this respect, provides an easy discharge path for static, thus, the source of ignition for dust fires is greatly reduced.
I also believe that higher levels of automated intricacy exacerbate rapid burn-ups, for the following reasons:
1) Additional hydraulic lines, once breached, provide a healthy supply of accellerant to an already burning machine.
2) Additional electrical load for automated systems, sensors, and comfort equipment means more wiring harnesses, more connections, and more points for invitations for disaster.
Finally:
The agricultural environment is brutal. Take out all the bitter cold, intense heat, cold, dry, wet, UV and abrasive soil, and the need to run hard for one month without stopping, then sit for eleven waiting, and you still have rodents.
Rodents, finding their way into places they don't realize they shouldn't be, building nests where we can't find them, chewing on everything and anything they can, to keep their teeth from overgrowing.
Chewing into wires, hoses, belts, and plastic...
...but not galvanized steel. Only one force trumps a mouse: Galvanized steel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 6:48pm
I agree with all of that 100%, Dave! Had I had about 30 minutes or an hour instead of 10, I would've definitely mentioned some of that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 6:58pm
THAT was AWESUM Creston! great job! if I were you, i'd send a copy of this to AGCO, they might hire you to do some presentations for them this winter! that should/would give you an edge over the othersand give you some more school/parents points!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 7:05pm
Thanks, Shameless!
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 7:06pm
Great Job!! I had to "sell" a Gleaner in my sales class in community college last spring. I had even less time than you had and know that I did not do as good of a job.
ryan
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 7:22pm
I just watched your presentation Creston and I must say you did a great job!!! Agco needs to hire you!  Ryan
McAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote McAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 8:03pm
Great presentation!
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 8:28pm
I sure can't improve on what all the others said,,
GOOD JOB
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 8:39pm
That was a very well done presentation. Congratulations to you. You didn’t just read a script but you kept it entertaining. That is not a gift many people are given. I have been watching gleaner road show videos with my 2year old son and to be honest you hit every point as well as the dealer promos. Well done.
Also makes me miss college when I was thin and had hair. And girlfriends.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 8:39pm
Thanks, both Ryans, McAllis, Michael, and Derek! I appreciate it!
We'll see what the Prof has to say next week when we (hopefully) get our grading rubrics back.
Edited by CrestonM - 15 Nov 2017 at 8:43pm
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 8:45pm
Good job on the presentation, I am forwarding the link to the IH friend who was looking at the Gleaner this fall.  On a side note, around here when farmers were running beans this fall, the fields that were the "greenest" (volunteer beans) were usually ran by the green machines too.  There was a light green from one set of tire tracks to another, and a fairly heavy stripe of green between the tires (separator or shoe loss).
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 8:49pm
Thanks!
Yep! I made sure to include that in my presentation. I included the photo from page 1 of this thread in my presentation, and when I described what those green stripes are and why they were there, everyone's jaws kinda dropped a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 8:49pm
Sorry forgot to mention on the rotor removal, they must have changed the stepped rotor then if you can pull it out the front.  The older rotor designs were stepped (larger rear diameter than the front) and couldn't go forward.  Sounds like they must have something going on with the rotor though yet if you have to remove that much off it to pull it yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 9:01pm
Yeah, I heard someone say once on the older rotors you had to pull the engine and take it out the back. Now that sounds like it would take a week to remove. Lol
It's hard to believe, for me at least, that even though the heart and sole of these Gleaners was pretty much designed in the 1960s, it is still unmatched today.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 10:24pm
Bravo! Bravo! Standing Ovation! Well done! Clap Clap Clap Thumbs Up Handshake
How blessed we are by HIS GRACE!
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 10:25pm
     Great job Creston. You make all of us on this forum proud to know you. And, yes, you could be the next Bien.    Duane
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
SCJR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCJR Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 10:48pm
Great job. We run a R76 with 35 ft draper. Deere dealer brought a demo s770 this fall. Yes it was very nice and would run about .5-.8 mph faster but seed quality in tank was not impressive at all. I'm not used to having dry pods in tank and when we tried to get them out had more splits. They are heavy pigs! There is still a lot of gleaners around here but the driving 2-3 hours one way for parts gets old. We keep a lot of parts/belts on hand and if not an emergency our dealer will direct ship from KC.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 1:07am
After watching your video, I'm ready to buy one even though my All Crop 60 does the job for me right now.
We know that some AGCO suits lurk on this site.  I sure hope one of them passes your video on to upper management.  Seriously, AGCO needs to hire you to promote Gleaners!
Edited by JohnCO - 16 Nov 2017 at 1:09am
Allis Express participant
ihc pickups View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihc pickups Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 8:56am
Excellent job Creston. Agco brass needs to see this.
Mike
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 10:38am
Very professional presentation, Creston.  Nicely done by a presenter that obviously knows his subject!Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 4:17pm
Thanks Jim, Duane, SCJR, John, Mike, and Phil!
John...I could sell you a S96...the smallest of the S9 combines, and it would be the closest in capacity to your 60, out of all 3 current models. Lol
But yeah...working for Agco doing something for Gleaner has always been sort of a dream occupation, but I never expected anything to come of it, unless I get an ag engineering degree or something of that magnitude.
I guess really my interest solely in Gleaner started when I was little riding in the L3 my grandpa bought back in '86. Even in the early 2000's, there was talk of trading that awesome machine in for a green one. At first I was on board, being raised a JD kid. However, the sentimental side of the Gleaners (that's all grandpa ever had) got to me, and that's the only reason I liked Gleaner to start with (little kid at the time) Once I was old enough to see past colors and really understand how things worked, my previous thinking that Deere was better was like a slap in the face. Even as a young kid I could tell it didn't look like it would work well, so I began to dig deeper into what made Gleaner the greatest machine ever, solely in hopes I could convince the family to hold onto the L3. However, I realized if its destiny was to end up in someone else's shed, I needed to wash the green paint off the family's glasses, per se, and make sure the next combine would still be Gleaner.
Luckily, the L3 is still in the barn, but my favor toward Gleaner is no longer just because grandpa had them (although I'm very proud of that). Rather now, I try to be unbiased in my explanations of the different combines to people, relying only on facts. I don't like it when people justify if a machine is good or bad based on their opinions/experiences with them, if they don't use facts as well.
