New gears and old gears |
blue924.9 ![]() Orange Level ![]() ![]() Joined: 22 Mar 2013 Location: George Iowa Points: 1089 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Jun 2017 at 4:41pm |
Got the wd running, when we removed the engine to overhaul it we also gutted the transmission to fix a wore 2nd gear that was making alot of noise. We ended up using parts from a wc parts tractor since the wd has the straight shifter. So now it has a combo of wc gears with low use and original wd gears that still looked very good. The transmission is now noisy in all the gears except road gear. I am wondering if the gears will quiet down once they develop a wear pattern with reach other. Before all gears but 2nd were quiet
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2269 |
The early WDs (straight shifter) have straight cut gears and they do make noise.
Since you have apparently "mixed" some gears the noise may be a bit more than usual. I personally don't think you have anything to worry about.
Albert ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: NW MO Points: 410 |
Sounds like you changed the 4th gear input shaft, I have seen this before. |
ctbowles58 ![]() Orange Level ![]() ![]() Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
we replaced 2nd gear in our CA and we put a new gear against a old gear now we have a "wine" in 2nd gear, they say it will set it self in time but it does sound bad.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8642 |
They are noisy from the beginning.Think you were trying to fix a problem that was just normal.Dad's new WD (now mine)has been noisy always.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24708 |
no, they are NOT noisey.....rather just saying " I'm happy to be in the fields again".... hehehe
Heck ANY tractor running and working is a GREAT thing !!! Jay |
No this second gear was definetly bad. It was pitted and wore on the teeth edge.
Before all others were quiet but not anymore lol Edited by blue924.9 - 18 Jun 2017 at 9:07am |
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
