New Forum / odd thing
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 4:49pm
Butch, ocharry, MIke, Ted,
Sounds like I'm years behind you guys. When I was growing up we never worried about all these things, we just shot. I just beginning to understand ballistics. Big rock vs. little rock. You can certainly can throw a little rock farther/faster, but you can definitely do more damage with a big one. Everyone understands that. Why then does a heavier bullet have an advantage at longer distance? I suppose it has something to do with momentum. I understand lighter bullets slow quicker. I have no doubt that I could throw a golf ball farther than a ping pong ball. None of this explains accuracy. I knew lighter bullets had less drop, thus must be more accurate. When my friend and I were at the range, I shot a tighter group at 200yds with his .223 than I did with my 30-06 at 100yds. I guess I was hoping to turn my 30-06 into a .223 by switching to lighter ammo. I'd like to thank you all for explaining the barrel twist will likely not allow this. I believe I need to do as y'all say, learn my gun, practice, and try different ammo to see what shoots best. It won't happen over night.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 7:41pm
Another thing you can check out is Remington "accelerator" ammunition, I do believe they still priduce it? It is a 22 cal 55 grain bullet in a plastic sabot. The 30-06 version was right at 4000 FPS as I remember or a tad faster than a 22-250. When I played with them years ago they were as accurate as the 110 grain 30 cal loads in my old 98 Mauser sporter and superior as for down range performnce.
Edited by Butch(OH) - 05 Mar 2019 at 7:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 8:02pm
I didn't know they made rifle ammunition like that. I remember seeing sabot shotgun slugs in outdoor magazines years ago. At one time I really wanted a rifled shotgun barrel for my Rem 870. I think their popularity must have faded.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 8:02pm
Remington Accelerators are no longer available. There is old stock for sale  on Cheaper Than Dirt or Gun Broker for around $40 a box. E Arthur Brown and Company has Sabots that can be reloaded in a 30/06 cartridge along with a .224 dia. bullet. Comes with load data for a bullet travelling 4'000 feet per second ! Here is a link. https://www.eabco.net/Accelerator-Type-Sabots-for-30-Caliber-Cartridges-100_p_13645.html
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 9:21pm
Ranse..the 30 cal. Just seems to do better with the 165-175gr bullets in a 1-10 twist at that 26-2800fps velocity.... Not saying your gun won't do better or worse....but I would bet it will do better than the 150gr stuff you are using....set up a target at 100yrds and shoot a couple 5 shot groups....with your 150gr bullets...get a couple different boxes of the heavier bullets to compare...box of hornady...box of federal...like that...at worst you have some extra hunting bullets....you just might find something better than you are using
I have a 308 that will make a 5shot ragged hole you can cover with a dime at 100 with 175gr bullets...they are hand loads but it shows improvement over a 168gr bullet...just for example
You are using factory loads BUT..if you look...something out there will shoot better than others
The heavier bullets do hit harder and carry a bigger smack down...they are also less wind susceptible.... They do not shoot as flat...BUT it sounds like you will be shooting at a given range...just zero there and learn a little hold over or under...it will come...unless you want to be a knob twister...lol...and then you can range twist and smack...lol
Just trying to help you understand some of this stuff
OR you could get a flatter shooting less recoiling rifle...with sweet trigger...phat barrel...oooh now them totes is in the danger zone fur shut
Nice 257..I like the quarter cals....uhhh...I will be quiet before I get us both in trouble
Ocharry
Edited by ocharry - 05 Mar 2019 at 9:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 9:41pm
Originally posted by Ranse Ranse wrote:
Why then does a heavier bullet have an advantage at longer distance? I suppose it has something to do with momentum. (1) I understand lighter bullets slow quicker. I have no doubt that I could throw a golf ball farther than a ping pong ball. None of this explains accuracy. I knew lighter bullets had less drop, thus must be more accurate. (2) When my friend and I were at the range, I shot a tighter group at 200yds with his .223 than I did with my 30-06 at 100yds. (3) I guess I was hoping to turn my 30-06 into a .223 by switching to lighter ammo. I'd like to thank you all for explaining the barrel twist will likely not allow this. I believe I need to do as y'all say, learn my gun, practice, and try different ammo to see what shoots best. It won't happen over night.
(1) Yes, momentum and weight, the biggest being weight.  Another thing that we haven't mentioned, (I think) is 'ballistic coefficient'.  That makes a difference too, but shouldn't get explained here unless someone else is VERY interested.
(2) Accuracy doesn't come from the weight of the bullet, rather the shape of the bullet.  ergo the coefficient.  Accuracy comes from a combination of the cartridge (bullet, brass, powder and primer), the rifle and the shooter.  Don't sell yourself or the rifle short.  The most failing component is you, then the rifle.  You can teach yourself to be a better shooter, but it takes time and $$ and a range and someone watching to see what you're doing wrong.  It's easier to see someones mistakes in rifle shooting than in trap shooting with a shotgun.
(3) Shootin a 223 is like shooting a BBGun.  You're not afraid of the kick, so you shoot better.  Even experienced shooters still flinch every so often when shooting something that makes our shoulder feel uncomfortable....so that doesn't tell you anything.  You needd a rifle stand and a bench rest so there is no human error involved to see how good a given rifle shoots.  Then you go from there.
Have faith and it'll come.  Just remember, steady, steady, squeeze, SQUEEZE...NOT PULL the trigger.  If you're doing it right, if you're squeezing and the gun goes off, startling you, you did it right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 5:52am
Ranse , shotguns and sabots in Michigan have somewhat faded away since the DNR have allowed hunters to use straight walled rifle cartridges such as the 450 Bushmaster. Less recoil than a 12 gauge and better accuracy and cost per round is less . Sabots are expensive ,usually from $12 to $15 for a box of 5. 450 Bushmaster is $25 for 20 rounds. I shot a Coyote at 100 yds. with my 450 Bushmaster. A 250 grain bullet travelling 2200 feet per second did not leave a pretty picture! One less Coyote to try and eat my Chickens! As others on this forum have posted with great advice if you are truly interested in shooting accurately get together with some friends and target shoot .And get a good rest and hearing protection. A friend of mine took a girl shooting who was interested but concerned about the gun recoil and noise. Jim started her on a .22 with good ear muff protection. She now hunts deer with a 12 gauge!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 11:45am
one thing that could be fun and help at the same time would be ,,,,,after you find the best shooting load for YOUR rifle,,,,cut a coyote silhouette form from some cardboard (that tan brown is about the same color,,,yotes may be a little darker at different times) and set him out there where you see the dogs,,,,and then commence to practicing hitting the dog,,,,,lol,,,yeah i might come over for some of that,,,lol,,,,dang,,,,little far to your house,,,,maybe i need a cardboard dog to shoot at,,,,lol
giterdone Ranse
ocharry
