New fenders for old trailer |
Joined: 11 Sep 2009 Location: illinois Points: 88474 |
Topic: New fenders for old trailerPosted: 09 Jul 2024 at 8:42pm |
Just for info--- for those with beat up fenders..
I have a 10 year old 18 ft 10K car hauler. Old sheet metal fenders have seen better days after hauling backhoe , bobcat, connex boxes... Pretty beat up. I had considered buying fenders made of 3/16 inch plate but they were around $500. I thought of making fenders from 10 inch c- channel, but they would be pretty heavy. While checking around i ran across something called JUNIOR CHANNEL. This was a 10 inch c- channel with 3/16 inch thick web and slightly thicker flanges. Weight was 8.3 pounds per foot .. so a 8 ft long section welded into a fender shape would be about 65 pounds per side.. PERFECT.. I bought 20 ft at the local Steel Yard and it was around $200. Didnt take long to cut the three pieces to make a fender with flat front and rear edges. I had a few scraps of 3/16 inch deck plate which i used to fill in the opening at the trailer deck... Getting the old fenders off was the biggest problem !! ![]() ![]() |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13729 |
Posted: 09 Jul 2024 at 10:38pm |
Well, Steve,,those look Great and no doubt will withstand a lot more punishment that all trailers that get regular usage will. I always shudder against that first dent with a new trailer ,,,,and after that first dent,,,,wwell,,,all them other dents come way too dang often,,,, ![]() ![]() Good Job,,,,!!
Posted: 09 Jul 2024 at 10:51pm |
yea... had a few dents.. then SON dropped a 20 ft connex box on the fenders and smashed one down to the tires... had to use a bottle jack to get it up high enough for running clearance.... NEW fenders should take as much load as the tires can support !!
Dirt Farmer
Silver Level Access
Posted: 10 Jul 2024 at 1:28am |
Them there are some very impressive fenders, they look like they would have been factory, good job, Ill have to remember your advice when I rework one of my round the farm trailers that get routinely abused. Thanks for doing the homework and passing it along
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34313 |
Posted: 10 Jul 2024 at 4:18am |
Bought this trailer used several years back, is due to repaint currently as time does not wear well. It also had the Tin Soft fenders where I added Tread Plate replacements from a Trailer Supply company.
Found them on a search for trailer fenders and were a direct install to OE Mounts. Standing up really well for beatings I have given.
desertjoe
Posted: 10 Jul 2024 at 6:06am |
While visiting the trailers subject,,,I've always wondered what engineering formula is used to determine the location that is used for placement of the axle,,(S) on the tralier frame,,,?? Like DMiller's trailer that has both axles way back from center of frame,,,,????
fjdrill
Silver Level Access
Thanks(1)
Posted: 10 Jul 2024 at 7:16am |
60/40 axle location works well on 20'.
Thanks(1)
Posted: 10 Jul 2024 at 8:02am |
The trailers I have built are made to my specs to haul a certain item, like an antique tractor. My axles are waaay back so I can drive the tractor on and place the center of the rear wheel over the center of the rear axle on the trailer. Makes my tongue weight correct and trails perfectly. Works well hauling cars to when I've had a dead one.
Thanks(1)
Posted: 10 Jul 2024 at 8:29am |
60/40 on the bed length is a GENERAL rule.... As Dr said, the most important thing is getting 10- 15% of the WEIGHT on the Tongue ..... weight distribution is different if your carrying a tractor or a load of gravel..
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24774 |
Posted: 10 Jul 2024 at 10:32am |
single axle, 60% back from the front of the BOX ( NOT the tongue...) tandems, 50% back these are the usual 'standards' posted. Now horse trailers and boat trailers are different......don't know why... My 5by8 trailer that I make are 100" long, so axle is 60" from front, dang EASY for even me to remember. They haul very very well.
