New exhaust manifold for 180-190-190XT gas engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Topic: New exhaust manifold for 180-190-190XT gas engine?
    Posted: 27 Dec 2025 at 3:31pm
I don't believe these are available at all anywhere, correct ??? If i'm wrong, please steer me in the direction where I might purchase one. So, assuming there aren't any available, I have plans to build probably two sometime this winter. They will be of 1/4" thick steel instead of cast iron and it shouldn't ever crack like cast iron does. If anyone is interested, let me know and I'll include you on my build schedule. Thanks.
Edited by DrAllis - 28 Dec 2025 at 10:11pm
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 6:37am
A friend of mine was looking for a new 190 gas manifold a few years ago. He bought the tractor cheap with a bad manifold. He is a decent welder and finally repaired his becasue he couldn't find a replacement.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 7:59am
DrAllis, maybe try welding up the OEM manifold? Problem isn’t the cast manifold, it’s the gas engine’s timing. Engine is set too lean, so it’s cylinder’s exhaust becomes a blow torch with flames pushing upwards thru manifold & out the muffler extension pipe? The high heat tempered manifold (+1500f) is cracking after engine shuts down & manifold cools to quickly? To remedy it, try setting timing 4-6 degree before OEM setting. That will enrichen it’s burn without any carb adjustments. It’ll cough some, but it’s Power will be fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 8:04am
Well, you might be right in theory, but you cannot time the ignition at anything faster than 25 degrees BTDC or the detonation will destroy the pistons. I know this factually from replacing broken pistons. I'm sure a good operator that lets the engine slow idle for a couple of minutes before shutdown would help reduce the castings cracking, but it's a known problem from back in 1964 up to the end. They made one manifold casting change (in the 70's) to try and help and I'm sure it did, but these days there's nothing new or good used available it seems. I'm beginning to wonder if i can even get the gasket that goes against the cylinder head. I'd rather start with new steel and fabricate something that I know will outlast a 50 year old casting that has been cracked and welded up as a repair.
Edited by DrAllis - 29 Dec 2025 at 8:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 8:26am
Right. Well then Ideally, a tuned exhaust header could suffice a lean engine. Tuned correctly, a custom header could scavenge hot exhaust while also improving power. Maybe a bit overkill though?
Are these “pullers” or farm tractors? Or both?
Two piece headers (1-3,&4-6) could remove heat even better?
Edited by AC7060IL - 29 Dec 2025 at 8:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 8:33am
Just farm tractors. I've built puller manifolds out of the same materials without any failures, but admittedly the 1700 degree temps only last for 10 seconds and then cool down driving back to the pits. Anyway, this will be fine as any of these gas tractors aren't plowing and discing anymore. it's just nice not to hear constant cackling coming from the exhaust manifold. Sounds like Jed Clampetts truck......
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 9:28am
Two piece headers would probably be easier to fabricate, and with the low overlap duration of these camshafts there is almighty little to be gained trying to build any extraction/tuning into the design for a farm tractor. A great big ugly low backpressure exhaust will work just dandy.
Your mileage may vary Smile
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 7:46pm
Is this the 262 6 cylinder gas engine we are talking about? What was the compression ratio on these from the factory? Would be nice to run one of these on dyno and check the exhaust temps at 25 degrees and then give it a couple degrees more advance and see what the readings are. I set my WD45 about 2 degrees more than the "F" mark. Sure works nice and starts nice. But of course I do nothing with it except for a couple drives now and then. I remember at home on the farm we ran a belt hammer mill with it. Ran it almost wide open when we were doing that usually for about 2 hrs. Exhaust manifold was cherry red. But back in those days we did not use a timing light. Probably just didn't know any better!!! Smile
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 8:09pm
No. The 230-262 family came from Buda's line. The G-2500 (265) and G-2800 (301) were new Allis creations in 1964.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 3:11am
 Early exhaust manifolds 4020190 needed the inside hole on the outer EX ports drilled out 1/16 inch larger for the expansion and contraction. Manifold 4021866 (effective with One-Ninety gasoline engine number 2G-15618) had the larger hole in them.
 They used lock-thread capscrews on the intake and exhaust manifolds and torqued the two capscrews at the ends of the exhaust manifold to 30-33 ft. lbs. and torque all remaining capscrews 44-49 ft. lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 5:53am
And then, if I have my events in order, they changed the exhaust manifold casting shape making the bends from the front and rear exhaust ports straighter, to try and eliminate cracking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 10:40am
Maybe exhaust heat transfer for gas atomization would not be functional? But, what If a D2800/D2900 exhaust manifold was swapped onto a G2800 & then it’s gas muffler be modified to bolt in place of turbo(D2900)?
Edited by AC7060IL - 30 Dec 2025 at 12:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 8:27am
Could an AC D2800/D2900 cylinder head be bolted directly onto an AC G2800 block? Maybe no cylinder head bolt alignment issues, head gasket issues, etc???
Reason I ask is that the cross-flow design of the diesels head should benefit the gas engine vs the OEM gas intake/exhaust manifolds on same right side of G2800 head.
Maybe plug the Diesel injector holes & drill/tap spark plug holes on its left side where G2800 distributor is located?
What are the chances a gas carb could be fabricated onto the D2900’s air intake & also accept its turbo for a modest 5-7 psi if waste gate was installed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 8:49am
2000-series blocks and heads all interchange without issue, gas or diesel. An updraft tractor type carburetor would be a challenge on the left side of the engine with the hydraulic pump and ignition distributer. Then, there would be the matter of the governor. I may get some time to think and design and maybe tack together something this weekend as I have Thurs/Fri off. I've got a 301 NA diesel exhaust manifold and want to see what it would take to get it on the side of the gas cylinder head, but I have doubts that would be possible with the intake manifold right next to it. I'll try and take some pics as i go along.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 8:56am
Downdraft carb attached to topside of D2900 intake that would accept a turbo top hat?
Fabrication to intake will probably necessitate carb mounting anyway? Why not fab it for a 650 2bbl Holley downdraft? Or any auto carb that allows easy access & assortment of fuel jet sizing for both farming or pulling setups?
Edited by AC7060IL - 31 Dec 2025 at 9:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 9:09am
If D2900 cylinder head could convert onto G2800 with larger carb fuel jets, turbo boost, etc,,, THEN custom 2 piece tuned scavenging exhaust headers would be the balls to give that cross-flow D2900 cylinder head it’s appreciated breathing power!!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 10:52am
Pullers convert diesel heads to spark plugs for methanol, or even gasoline pulling engines. The diesel conversion helps with higher compression ratio too. The conversion would be an ideal application for Dave Kepners DJ Update EFI system he makes for JD gas tractors. Dave lives here in Walnut, though I am not involved in his systems, and he doesn't want to branch to other brands, but Dr could lmao!
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:41pm
We have had a marvelous start to 2026 !!!  Who would have thought a diesel exhaust manifold from a 180-185-190 or Gleaner "F" would bolt right on a G-2500 or G-2800 cylinder head ?? Well, it certainly does and with about 2 minutes worth of grinding on each end mounting holes.  With every discovery like this, there is usually a downside. The one thing I will have to fabricate is the up-pipe from the diesel manifold to the muffler. The diesel pipe is 2 inches closer to the valve cover so the muffler either needs a new hole in the hood or an up-pipe with a jog in it. A very minor detail compared to fabbing up a whole complete exhaust manifold !!! There are tons of these diesel manifolds in salvage yards to be had.  I may have to fab up some sort of heat shield to warm up the intake manifold in the center. Probably not needed in summer temps but winter temps I can see why it might be needed. It will be bolt on and could be removed if desired.
Edited by DrAllis - Yesterday at 3:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 55 minutes ago at 11:29pm
Well HAPPY NEW YEARS Doc!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 52 minutes ago at 4:32pm
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 32 minutes ago at 4:52pm
FOR FARM USE- suggest a 1" channel laid on top of the intake - weld up the ends - and put a fitting in the exhaust probe hole and direct it down to the box via fitting. Probably gonna need some heat in the intake for efficiency and eliminate lean condition or allow a leaner mixture for general use.  (not that a gas XT would burn a lot of fuel anyway :-) )
I had mocked up a turbo manifold on a XT and mentioned it on here when I think it was Doc that said, and what are you going to do with it at 8 gallon per hour and gas was $4 at the time... I put back stock and sold the XT gas , I wasn't thinking - just playing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 6 minutes ago at 6:18pm
My plan is to build a simple steel box around that area that needs heat, secure it to the outside two existing intake manifold bolts and then going up as high as the pyrometer probe hole and then up to the muffler u-bolt clamp. This will help support the weight of the muffler and keep it from turning. But for now, the main goal of a solid not-cackling exhaust manifold has been achieved !!   Interesting how the 180 intake manifold throat looks like it has a NASCAR restrictor plate (4022853) slug pressed inside  it. The restrictor slug measures only 1.125" I.D. and the throttle plate bore on the Zenith carb measures 1.250".  This small throat isn't on the One-Ninety or XT gas tractors. So, besides slowing down rated speed to 2,000 RPM and a smaller carb, the restricted throat choked the HP down to 65 at the PTO.
Edited by DrAllis - 3 hours 54 minutes ago at 6:30pm
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 1 minutes ago at 6:23pm
Now we need to hear how it sounds Smile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 44 minutes ago at 7:40pm
DrAllis, that exhaust manifold looks excellent! Wonderful job! Maybe don’t lock-down/completely tighten your planned fab’d intake heat box to exhaust manifold &/or /muffler clamp? Let intake do most of supporting muffler? Do Attach it loosely to exhaust manifold but allow for it’s necessary freedom of movement for its heat cycles?
