New additions WD Oxnard High Crops
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Topic: New additions WD Oxnard High Crops
    Posted: 31 Dec 2021 at 11:40pm
Just got these 2 in on Wednesday night.
One has 38” rears the other one has 42”
Came from Ca.
Ryan winter pick up the tractors.
Daniel Moss got them from Ne. To Rolla.
Have to get a couple flats fixed and see what else they might need.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 8:11am
Interesting finds. Do they run? Am I correct in assuming that the brackets on the tractors are the remains of cultivators?
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 8:36am
Had to take cultivar off to haul. Have them. Oxnard cultivars
Edited by rtwfarm - 01 Jan 2022 at 8:38am
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 10:03am
One looks like a WD-45. 4-bolt wide front. Maybe has the WD-45D ring and pinion?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 3:28pm
Both motors are loose.
Just had enough time to check water in the transmissions and pull the plugs
Got the flat tires up on blocks.
when it warms up some and not raining will working on see if can get them to run.
Pulled the plugs and used air to make sure any water is out of the cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 3:33pm
Good find , but dang there rough ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 6:03pm
Not really these are way better shape than the stuff out of La.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 8:54pm
You sure find things in the darndest places Richard.
What kind of road speed do you think they have?  LOL  I'M NOT going to test em out...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 9:23pm
what might you be doing with all those high crops you bing home.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 10:20pm
Those stopped by my place! I'm glad they got there safe, one heck of a load once it left.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 11:18am
yes I agree  Daniel had few on the trailer.
We use some and just like High crop tractors.
Want to have WD 45, I already have a WD that is fixed up in my collection.
This page was generated in 0.088 seconds.
