New 7040 has clutch issues.
Mattman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Topic: New 7040 has clutch issues.
    Posted: 01 Sep 2024 at 9:28pm
Added another 7040 to the Allis collection this week. I picked it up from an auction in Iowa. I did a lot of work already. I fixed a cracked dash. I replaced range cable. I brazed hole in radiator. Its in nice shape but clutch has little to no resistance. I can push it to the floor with 2 fingers. It doesn't seem to be slipping. Trans brake works well. Its just too soft. Linkage all looks ok too. Not sure if I have a hydraulic problem or a worn out clutch. Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2024 at 10:40pm
Run it- does it slip then ? Open it up,, you will find the problem
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 6:07am
Broken return spring on pedal
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 7:06am
You didn't say, but it is a Power Shift transmission and the clutch pedal return spring is broken inside the instrument panel area.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 7:40am
I don't see a gear shift lever or a transmission filter in the picture, so I'm going to assume that it's a power shift also. Usually, if the spring breaks, the pedal won't return upwards. I wonder if someone with a weak leg has replaced the original spring with a lot lighter one.
Edited by Lynn Marshall - 02 Sep 2024 at 7:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 7:54am
The pedal returns as it should and the spring is not broke. This is a power shift transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 8:09am
So, if the inching pedal returns 100% fully, there is no problem. Power Shift transmission inching pedals push easy compared to a Power Director. I'll bet it had a broken spring at one time and what was used to replace it is probably a little weaker than OEM. Again, if the pedal comes 100% fully UP, there is not a problem. Carry on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 8:21am
I like that chick on the right of that pic Lynn,,
Edited by DougG - 02 Sep 2024 at 8:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 8:26am
The power shift tractors don't use a clutch cable like the power director tractors.  The cables can get stiff and stretch over time on those models. It is just a rod and mechanical linkage to move a spool in and out of a valve body, on a power shift. Neither model uses a dry clutch with a pressure plate, release fingers, or throw out bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2024 at 7:20pm
So I figured out my light clutch issue. Previous owner had a power Director spring instead of heavier spring and link installed. I have all the correct stuff on it now and the clutch feels good. I found the pin on the floor for the power shift linkage. I am assuming it was a mixup at the service counter years ago. Thanks again.
