'new' 59 D-14 info needed |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25246 |
Topic: 'new' 59 D-14 info neededPosted: 25 Jan 2010 at 1:10pm |
Hello.Have a couple of questions about my 'new' D-14.
1) the lift latches have holes in them for a 'pipe'? Just wondering what they're used for as my 57 doesn't have them.
2) The operations meter needs repair,at least a new needle.Seems the screws holding the dial portion backed off.Also are new (repro) dials available.
3) Is the grille supposed to be white?
Man I was sweating all day couldn't get on until now....without this forum I'm a wreck !!!
Worse than NOT having coffee!
Thanks
Jay
john(MI)
Posted: 25 Jan 2010 at 1:48pm |
A 57 would have an orange grill.
RichinWis
Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Posted: 25 Jan 2010 at 7:55pm |
The holes in th lift latches are for a solid steel shaft, not pipe. It is for rigidity picking up bigger implement's. although the ones with the holes in them are not for the D14, just D15 on up. of course they will work fine, just not correct for the correct police.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 25 Jan 2010 at 9:43pm |
My 58 does not have the holes, but the 59 I picked up has them - could have been an option. Your grille should be orange as well. Lots of vendors here sell new tachs.
I am currently looking for a tach drive for the 59 if anyone knows of one.
DSeries4
Posted: 25 Jan 2010 at 9:49pm |
My mistake, if you have a 59 D14, it should have the black bar grille.
Brian Jasper co. Ia
Posted: 25 Jan 2010 at 9:50pm |
According to Swinford's book, in 59 the D14 starting at serial # 19001 got the black bar grille.
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2400 |
Posted: 26 Jan 2010 at 6:57am |
Jay, I found a new ops gauge and several other gauges from one of the suppliers on this site. Had my TB gauge rebuilt but it still isn't working.......disappointing as it wasn't cheap. One of these days I will run an independent hydraulic line to it to test it. Or maybe there's something blocking the hydraulic fluid flow to it. When I bought the tractor, there was a plug where the line plumbs into the tranny. I was able to buy a used line from one of the fellows on here which I used when I installed the rebuilt gauge. Another project!
WC, CA, D14, WD45
MBwcIll
Joined: 03 Oct 2009 Location: Chapin Ill Points: 175 |
Posted: 10 May 2010 at 4:32pm |
Long about 62 the latches started coming from the factory with the bar. Also they started beefing up the lower "hook" to twice the thickness as the early ones. Over the years replacement parts, were the latches with the hole in them, you are asking about. Your original ones probably needed replaced at some past time, It is my belief as the mounted tools got larger there was a need to add the bar to stiffen the lift arms. Look at what the early WC/WD style used and also the need to have some sort of safety release changed the latches over the years.
norm [ind]
Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
Posted: 10 May 2010 at 8:16pm |
we have a ta ch drive an new repo tachs call 1-800-254-3116
David Maddux
Posted: 10 May 2010 at 8:39pm |
I have been told that if you were pulling a plow, and you tried to turn before the plow was completely out of the ground, the bar keeps the arms from snapping off.
