never seen a hd6 like this
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Topic: never seen a hd6 like this
    Posted: 02 Jun 2017 at 3:02pm
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 7:06pm
Looks like a 7000 turbo motor.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 10:16pm
Interesting way of mounting the blade lift cylinder, looks like it works though.
Allis Express participant
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 11:37pm
someones super modified custom HD6 for sure.
6 roller track frame; with new undercarriage. Adapted hyd 6 way blade. Not so sure about the single ram mount; but maybe ok; looks like it was a super smart guy that fabricated it all up.  Yes could be a 7000 motor as exhaust pipe looks to have a lower curl in it to come off a turbo.
Base tractor looks to be a wet backend HD6E rather than a dryend 6B as can,t see any steering levers coming out of the floor.
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 11:39pm
might even be a HD6EP; as can,t see a master clutch lever; or a gearshift lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2017 at 5:30pm
I saw a hd 6 similar to this one a few years ago on cl. It had the blade like this with the push arms inside the frame but the rams were normal hd6 but it had a square fiat type radaitor guard i wish i had saved the pic but didnt. It was branded fiat but this one the rams are set up like terex
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 9:16am
I think it is a factory special order mostly because it is done so completely well. It looks like the undercarriage is from an HD6G
I would like to see more pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 3:13pm
guy added more pics
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 3:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 4:21pm
I would suspect that to be a truck transported fire or MO dept of conservation unit that was sold at auction years ago. They built them to fit inside small straight trucks flatbed platforms as they would be light enough to do that.
