Neoprene cement
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: Neoprene cement
    Posted: 26 Nov 2014 at 6:52am
Is there a modern alternative to the neoprene cement AC used to adhere rubber gaskets to metal like on dozer final drives?  i am calling Minnpar to order a gasket  to fix my leak but I will be need to adhere it to the final drive housing.
  I plan on asking minnpar about it but was wodering what others are using.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2014 at 9:41am
3M ScotchWeld Nitrile High Performance Rubber And Gasket Adhesive 847 is a premium quality, multi... Read full product description ...
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2014 at 11:45am
Caterpillar have their version of it Cal, but I dont like the price tag. I use upholsterers glue (Ados F2). Works just fine. Also use it to stick gaskets to oil pans and anything you want them to stick to. Diesel mechanics put me on to it many years ago
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2014 at 6:16pm
GM weatherstrip adhesive, or contact cement also work pretty good.  Also indian head shellac works pretty good, too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2014 at 7:17pm
thanks for the input guys.  i have indian head , but if there is something better id like to use it because splitting the track and moving the truck frame is a real pain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2014 at 9:14pm
the 3M 847 I used and when doing repairs on production machines where i worked we used for many things as it held up to oil, acids and caustic , So many a gasket or seal was put in with it as the sealing or gasket compound to prevent leaks , we had it in tubes and 1 qt cans and used a paint brush to apply it .
