Neglected Allis Chalmers 720 TLB |
Heliarc
Joined: 23 Jun 2019 Location: Shickshinny PA Points: 74 |
Topic: Neglected Allis Chalmers 720 TLBPosted: 04 May 2025 at 5:09pm |
Brought this home yesterday. It's certainly a project but I think it'll be an awesome machine when it's up and running.
I figure I can do a better job showing what I go through on video. Seller said something about this is one of seventeen configured this way with a loader and backhoe. I don't know but once it's working it's going to be great! https://youtu.be/1x5U2iTbxfs Edited by Heliarc - 04 May 2025 at 5:12pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4261 |
Posted: 05 May 2025 at 10:38am |
thats a neat set up, take the heads off it might be locked up from carbon deposits on the head
Heliarc
Posted: 05 May 2025 at 1:13pm |
Filled the cylinders with ATF/Seafoam. All I had was Seafoam so I figured can't hurt. Left it overnight. Took the cover off the shaft to the rear PTO and used a pipewrench on the shaft. It came loose with little effort. Back and forth a few times until it would roll all the way through, rolled it over ten more times then rolled it over a bunch on the starter. Right side compression is currently 90PSI, 115 on the left. I figure there's some junk in the rings on the right side.
