Need suggestions
CharleyH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CharleyH Quote  Post ReplyReply Direct Link To This Post Topic: Need suggestions
    Posted: 21 Apr 2022 at 9:33am
I am restoring a 611ltd and the plastic dash panels are faded. Does anyone have suggestions for what to use to return these to black? I have tried paint and was not satisfied and the restoration polish for vinyl cladding didn't work. I am hoping someone has a solution.
Thanks, Charley
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2022 at 10:51am
Did you use the spray paint specifically made for plastic? That has worked well for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CharleyH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2022 at 1:31pm
No, I did not think of it. Thanks for the help. Do you know what brand you used?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2022 at 1:40pm
there are a few brands that will work well... the main thing is to CLEAN the parts and PRIIMER with something that sticks well to the plastic... then paint...
Google " paint plastic car parts" and you get a lot of info and You Tube videos.. Many are professional and use air sprayers... There are some that use rattle cans, but need SPECIFIC type.
Edited by steve(ill) - 21 Apr 2022 at 1:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CharleyH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2022 at 1:53pm
Thanks for your help!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2022 at 8:27am
I use Rustoleum's Matte Black Trim & Bumper paint. Works quite well. P/N 251574. Like anything else, the surface needs to be super clean.
Steve@B&B
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2022 at 11:00am
I have used a plastic primer paint , then a plastic paint , then top coated with regular rattle can color I needed . The first 2 coats can be light spray on clean surface to get a good bond for the finish color
Post Options Post Options   Thanks (0) Thanks(0)   Quote CharleyH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2022 at 8:25pm
Thanks for your help guys. The experience and knowledge on this forum is so much help.
This page was generated in 0.977 seconds.
