Need source for AC forklift starter?
Broncobilly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Broncobilly Quote  Post ReplyReply Direct Link To This Post Topic: Need source for AC forklift starter?
    Posted: 02 Nov 2012 at 9:56pm
Anyone know of a source for a new or re-manufactured starter, for an Allis Chalmers FPB 20-24 (1 ton lift capacity) forklift?  The engine is a Waukesha FC 133 gas four cylinder, manual trans.  I believe it is an early 1970's model?  Some of the digits on the data plate are wore off, so I haven't emailed the AC historical site, to verify it's age.  I brought the starter to NAPA, and they couldn't locate a replacement.  I then ordered a starter online, from a small engine suply (said it would fit an FC 133).  Tried to mount the new starter today, and it doesn't fit!  The start I received from the supply house, has an external solenoid, which won't clear the trans bellhousing.  The original starter, has no external solenoid.
The original starter has a MAK 4001 marking on it.  I found on Google; that this marking indicates it was manufactured by Autolite, and it appears to have been used on a 1938-1940 American Bantam automobile.  Again; the NAPA folks were clueless with this info.  Any help is appreciated!
TIA!,
Broncobilly
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2012 at 11:06pm
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2012 at 11:12pm
Contact Herc U Lift Parts Department @763-479-2501. Maple Plain, MN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Broncobilly Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2012 at 11:19pm
Ages Cat,
Thanks for that info, I will call them on Monday.  From the pic posted by Coke-in-MN, it appears that my oem starter is missing the spring on the starter shaft?
TIA!,
Broncobilly
This page was generated in 0.081 seconds.
