need some help
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: need some help
    Posted: 27 Jul 2014 at 6:29pm
I have a 3416 hydro that I need to replace the seal and bearing on the pump drive shafts and I'm having no luck can someone tell me what the part number is for the bearing and for the seal. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2014 at 7:08am
Usually bearings have numbers stamped on them. On occasions, some seals will have an ID or production number on them where they can be interchanged over. Do you have the bearing and seal out? If there is no number on either, a bearing shop should be able to ID both by measuring up the sizes, and then interchanging the sizes to a number out of their books.
Steve@B&B
Edited by Steve in NJ - 01 Aug 2014 at 7:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2014 at 7:39am
I got the seal and bearing out I called my local ac dealer and that told me the bearing was obsolete and they had a hard time finding the seal. I found a bearing at Napa. Thanks for the reply.
