Need some help on a good used D-17 Radiator
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Topic: Need some help on a good used D-17 Radiator
    Posted: 05 Jan 2011 at 9:14pm
  I am trying to help a friend of mine out, he has a Series  3  D-17  and the radiator is leaking on it . It has been fixed years ago and has since started to leak agian. If anyone has a good used one send me a pm .  thanks mark
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 2:30pm
I wish you good luck, all the ones I was able to find were in about the same condition as I had.
Check with your local radiator shop about recoring yours, might be the best way to go.
Pullin With AC
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 2:40pm
New aftermarket is not that high of a price to pay,cause the tractor is useless with out a good one!!!!!!!!
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 3:00pm
A recore from reputable shop is money well spent.There are some CHEAP cores out there.A good one the first time and yer done.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 3:04pm
Watch those repros! Many are not cored the same.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 6:57pm
Good used radiators fall into the same catagory as good used tires and good used tin, you may get what you paid for, or not, your friend will be much happier to have a pro look at his rad, it may only need another repair , at worst a recore. I would only sell someone a new radiator is if the tanks and or side straps justified replacement.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 7:19pm
  we have new in stock   1-800-254-3116   may have a used one at shop taken out of a tractor    coputer at home    will check fri. morn
This page was generated in 0.083 seconds.
