need plow shares
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Topic: need plow shares
    Posted: 09 Mar 2010 at 10:30am
I need 2 plow shares for a 52 plow. price and shipping to 47240? thanks!
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 10:40am
Jay - If you can't find what you need try  -  AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 10:42am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 1:31pm
ITs insufficient  information to say plow shares for 52 plow. In AC that means the plow FRAME, but not the bottom. Bottoms were in a separate book and many bottoms customized for different soil types were available. You have to fine a part number on a bottom part (frog, share, moldboard, shin, or maybe landside though landsides were used on many bottoms) and from that the plow bottom can be identified, and then the proper share identified.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 1:32pm
FIND not fine a plart NUMBER!
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 1:52pm
yeah, thats right, I forgot. Ill take the tarp off it when I get home and look for some numbers. Thanks!
acdeerboy123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdeerboy123 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 2:40pm
no more balsters, Less died this past winter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 2:45pm
Keep in mind that the plow bottoms book lists from 6 to a dozen plow shares for a particular bottom, depending on plow width (12, 14, 16) and the ground. Some are short some are long. Some are used for a couple widths. Some have point turned down for deeper suck, some don't. Some are made of steel, some of chilled iron, some a combination. So are toughened for rocky ground, some aren't. Some have a special hard surface to wear longer, some have a soft center to handle impact better. Lots of variations, most of which won't be available today.
Gerald J.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 3:53pm
Sorry to hear that Balster's has closed, especially due to death.  I would give my left arm to walk through that building.  I drove past it twice, but there was never anyone around to talk to.  Will there be an auction?
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 4:22pm
plart NUMBER Gerald??  dont ya just hate it when that happens???!!!!
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 4:30pm
Also in need of 2 shares for a #52 plow with 12" bottoms
Will look for a part number on our worn set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 5:21pm
Skip, its happening more often. I don't appreciate this gray on black entry screen. I may have to tell my browser to use my own colors for this forum so I can see ALL the text.
Gerald
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:35pm
  PUT NEW NOSES ON THE POINTS  HAVE REPAIRED MANY
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 6:13am
I think I have a book that lists the numbers for the G plow points. I'll post them when I get home, maybe in a couple of weeks.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2010 at 6:35pm
These are for the G #24, 124, & 325 plow. The 24 & 124 both use the part # 309141 frog. The #325 uses the part # 319721 frog.
The G plows are 12".
S.C.S.   Soft Center Steel
S.S       Sold Steel
N.C.     Narrow Cut
D.S.     Deep Suck
#24 plow.
Part #
309414            frog
308860            S.C.S.
308863            S.S.
309270            N.C., S.S., stoney
308866            Chilled Iron
309235            N.C., D.S.
309234            N.C., D.S. stoney
#124 plow
309141           frog
308880           N.C., D.S.
308860           S.S.S.
308863           S.S.
308866           Chilled Iron
309235           N.C,D.S.
309270           N.C.,D.S.,S.S. stoney
309234           N.C.,D.S. stoney, Chilled Iron
309262           N.C.,D.S.,S.S.,                14"
309271           N.C.,D.S., stoney            14"
309263           N.C.,D.S., Chilled Iron     14"
308887           Chilled Iron
309264           N.C.,D.S. stoney, Chilled Iron
#235 plow
319721           frog
308800           S.C.
308803           S.S.
309245           D.S.,S.S.
They must have used some 14" points/shares on the G 12" plows.
Dusty
Edited by Dusty MI - 20 Mar 2010 at 6:48pm
