Need opinion...... |
donkey
Joined: 06 Feb 2012 Location: Central MO Points: 152 |
Topic: Need opinion......Posted: 01 Mar 2012 at 8:57am |
Morning everyone,
Is a "B", "C", or "CA" large enough to maintain less than 10 acres? Would consist of brush hogging about three acres a couple times a year and maintain the 500' driveway. One with a sickle mower would really be handy along the road. Last tractor I used was Belarus FWA 65 hp and I spent all my time turning. Am I better off stepping up to WD or WD45 for the money? Thanks Jeff |
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 01 Mar 2012 at 9:11am |
Depends on how much time you want to spend in the seat . We cultivated 50 acres with a farmall cub one year and it was about half the size you mention.
CTuckerNWIL
Posted: 01 Mar 2012 at 9:15am |
I would look for a WD or 45.They might use a little more fuel but get more work done faster. A CA might be handy but not as cheap to buy as a WD.
My Dad farmed from 1951 to about 1967 with nothing but a CA with 60 tillable acres. |
JimD
Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
Posted: 01 Mar 2012 at 9:20am |
Usually you can find a WD for almost the same money as a B. The B is easier to haul, but the WD's hand clutch, weight, and easier to use hydraulics would make me grab the WD first almost every time.
JImD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543 |
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 01 Mar 2012 at 9:22am |
Jeff
A CA will handle a 5' brush hog and pull a back blade just fine; since the B and C have the same engine and similar power, believe they would work also. Personally would not use a B or C for brush hogging without an overriding clutch on the pto; the hand clutch, better hydraulics and 4 speed tranny make the CA a better tractor than the B or C. A WD or WD45 would probably be a better value, have more power, and are more readily available than the CA.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
donkey
Posted: 01 Mar 2012 at 7:44pm |
Does a B, C, & CA all have the same engine?
Stan R
Posted: 01 Mar 2012 at 8:19pm |
I'd go for the CA. My father had one when I was a kid and it was a great tractor. Besides, do you really want to finish the mowing fast??!!
donkey
Posted: 01 Mar 2012 at 8:26pm |
I am with you Stan great way to relax!
CTuckerNWIL
Posted: 01 Mar 2012 at 8:39pm |
Pretty much. There were changes over time but the later B's had the same CE engine as the CA. The block is the same, early B's had a smaller bore. When the C came out the engines went to the CE which had the bigger bore. |
Protrucker
Joined: 25 Apr 2011 Location: Broome Cnty,NY Points: 718 |
Posted: 01 Mar 2012 at 8:49pm |
So, what year would the B's have started having the CE engine?
CTuckerNWIL
Posted: 01 Mar 2012 at 9:12pm |
Bryan Smiths website say 1943?? I thought they came out with the C in 1940.
allismanamp
Posted: 01 Mar 2012 at 9:18pm |
for 10 acres i would cough up the extra cash and get a nice CA allis with a wide front and a 3 pt hitch they are one of the most affordable tractors to run when mowing and are nice and small for getting turned around and getting around things i have used both the 45 and the ca model allis tractors and my little CA is great and much easier to turn than the 45 unless you find one with power steering but that is just my 2 cents i know the CA allis are sot after by lots of collecters and hold there resale very well but i would never part with my CA i love that tractor and know what i have after redoing everything on it all thats left is the paint and i know once i do that i wont want to work with it anymore so for now it will stay my A1 work tractor
~AMP~
ewbs79
Joined: 17 Mar 2011 Location: trenton,mo Points: 81 |
Posted: 01 Mar 2012 at 9:35pm |
Wow that's alot of information so basically if I was to try one of the two on a baler the c would be a better choice but either way its probably going to be a headache their both going to operate same speed same motor but where does the extra hp come from with same ground speed and hp
ewbs79
Posted: 01 Mar 2012 at 9:38pm |
Sorry last post wrong subject lol
