need new switch for my 12 vdc winch |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13773 |
Topic: need new switch for my 12 vdc winchPosted: 28 Jan 2022 at 5:51pm |
I need to replace the up-down rocker switch on my 12 volt winch. Thought I could use a regular ON-OFF-ON toggle switch and first thing that happens is the winch is coming IN aand I cannot get my big azzed thumb on the friggin toggle switch to switch directions,,,,,,,,so the whole friggin thing jams while I'm trying to find the friggin switch,,,and promptly burns the switch up,!!!!! What I NEED is a type switch that is spring loaded to return to OFF (Center position) when I get thumb off, the switch,,,!!! I find some on Grainger that are 6 pole and some that are 3 pole,,,,? What's the diff the control cord only has 3 wires,,,, AND none of the switches say they are spring loaded
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25296 |
Posted: 28 Jan 2022 at 6:04pm |
OK, you need a SPDT momentary, center off switch Single Pole Double Throw, means 3 contacts ,a center common that will connect to 1 of 2 other contacts. Momentary, means you gotta HOLD it 'up' or 'dn' to make it do something, let go, it STOPS Center Off, means it has 3 positions. When 'released', it return to center, and NO power goes anywhere BTW you NEED a switch rated for DC power NOT AC, probably 2 amps is OK.Probably anything that fits will work as relays are low power. The switch powers one of 2 relays that control the winch power Now you might be able to get them from say Harbour freight as a repair part,or whoever sells winches. That switch is probably a common part. Have 3-4 of them in garage,but it's a loooong walk to New Mexico !
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55326 |
Posted: 28 Jan 2022 at 6:17pm |
TomC
Joined: 24 Nov 2017 Location: Hillsboro, MO Points: 1549 |
Posted: 28 Jan 2022 at 7:02pm |
Maybe check with an RV dealer, the landing gear switch on my 5th wheel is a rocker switch but you have to hold constant pressure either up or down, my last 5th wheel was the same way..
desertjoe
Posted: 28 Jan 2022 at 8:17pm |
Hey Jay and Tom,,that right there is what I NEED,,just didn't know what to call it,,,,these are the times I dislike living in these small towns cause ain't nobody carry much and with the current supply issues,,,,its even worse,,,,,,, dang brandon,,,,, Hey,,Dave,,,MANY THANKS,,, for that link on Surplus Center,,,,I just placed an order for TWO of them switches plus a catalog. I had joined up with them many years ago when I bought all them new hydraulic hoses for the D14 back hoe/ loader,,,but I could not remember my PW so I had to log in as a guest
Edited by desertjoe - 28 Jan 2022 at 8:17pm |
DiyDave
Posted: 28 Jan 2022 at 8:39pm |
Joe, I still ocasionally buy from them, their prices aint terrible bad, they do whack you with shipping, but they know how to pack stuff in a box, pretty efficient. If nothing else, using their search tools sometimes jogs a memory as to what to call the item you are searching for...
