Need luck wd45 at auction this Saturday. |
Page <12 |
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5040 |
Since it's not a tractor from your family, it drives the value down for you (or at least it would for me).
By your description, it sounds like it has been sitting a long time. You are probably looking at a complete engine rebuild, which can easily run $1000 or more. If the rear tires don't turn, that is going to be more work and expense. If you need tires and / or rims, more money. The other thing with tractors that have been sitting, is there is often a reason they were abandoned. Did it have some kind of major problem that was the reason it wasn't used? My feeling is if someone gives you a good running WD or WD45 and you have to buy new rear tires and rims, you have more in it than you can ever hope to recoup if you decide to sell it. Around here, WD45's are very plentiful and it's quite easy to find a good running WD45 with decent tires and rims between $1000 and $1500. Keep that in mind when you are bidding.
ryanschott ![]() Orange Level ![]() ![]() Joined: 10 Apr 2010 Location: michigan Points: 612 |
I’m assuming brakes stuck cause trans shiftsnice. How can I undo the brake bands quick
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1939 |
Maybe whoever moved it didn't know how to release the brakes.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8648 |
First item is to check that the brakes aren't set.Regular folks don't know how to set or unlock em.Dont think this style brake is likely to rust tight.Would pull top covers and look in.Use prybar to wiggle shoes.If they move, they're not stuck.Otherwise stuck in 2 gears or rusted internals.
allisbred ![]() Orange Level Access ![]() Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Remember to check the coolant level. Good luck today!
dawntreader74 ![]() Orange Level ![]() ![]() Joined: 28 Oct 2013 Location: Manteno Points: 1770 |
the pin at the bottom of the shoes is stuck from sitting' most like. had to free one up the other day' just sat haft the summer. one side was locked up;
Matt (NEIA) ![]() Bronze Level ![]() Joined: 20 Sep 2009 Location: Butler Co. IA Points: 168 |
Never seen a loader like that one kinda neat.
1955 WD-45 with factory PS
JayIN ![]() Orange Level ![]() ![]() Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
Good Luck! I would think $500 would do it!!!
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5902 |
The Auction picture shows it sitting outside with the rear wheel sunk deep in the mud. With the exhaust not covered, it for sure is going to be rusted tight. Gary |
Didn’t get it the trans both clutches and rear are froze up long with motor so was really bummed but would have went the extra miles because of the history. So crazy guy came in and bid it up to 1250 cause he wanted a project. There’s tons on Craigslist in our area for 700 why not buy one of those. Oh well still have a pocket of money
$1250???? Two people are nuts!!! The one that won the bid and the #2 guy!!!!
FloydKS ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: S E Kansas Points: 8423 |
you are coming out on top |
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Maybe he was family too?? Knew the history also?
Sounds like you got the better deal. Sometimes it doesn't seem that way, but when you see what God has in store for you......... |
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3093 |
You never know at auctions that is what makes them interesting.I picked up a pretty good Oliver 66 with a good rear blade too at an auction for $700 today.
Kenny L. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: NEIOWA Points: 1360 |
I agree with you Gary I went to a auction that had a allis barge wagon it was raining and kind of chili that day and figured it would be following me home or hope it would but it didn't the other person had deeper pockets then mine but I made him go deeper into his that for sure. Kenny L.
Ted J is correct on all parts. Go look at those 700$ tractors an learn from all until you find a comfortable buy. I know it’s fun working on them, getting them going. You still need to figure you cost getting them in good running condition.
Page <12 |
