Need Help with torque spec on AC 2900 Engine
steveng0143 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steveng0143 Quote  Post ReplyReply Direct Link To This Post Topic: Need Help with torque spec on AC 2900 Engine
    Posted: 29 Oct 2010 at 11:06am
I looking to put a new head gasket on my AC 2900  301ci engine and would like to know the correct ft-lb torque  I need to put on the head bolts.
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 1:50pm
Up to 1973 the spec is 150 ft. lbs. and after that it is 165 ft. lbs. and the rocker shaft is 28-33 ft. lbs.
I usualy use the later spec no matter the year of the engine.
Pullin With AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote steveng0143 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 3:11pm
Thank you very much, one last thing? What is the correct bolt pattern for torquing these down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steveng0143 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2010 at 7:57am
ttt
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2010 at 9:13am
There is an exact sequence in the manual but I don`t have it in front of me, I have always just started in the center,worked to the ends in an X pattern, and take the bolts down in three torque steps. i have never had a problem with thiss method.
Pullin With AC
