Need help with D-17
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Topic: Need help with D-17
    Posted: 01 Feb 2010 at 10:02am
I have 1963 D-17 ser.3 and need to replace O-rings on power director shaft that  the shift lever attaches to.Can I do this sliding the shaft one way to replace one O-ring and then slide it the other way to replace the other O-ring or do I have to remove the side plate on right side of tractor? any help would be really appreciated. Thanks !!!
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 10:40am
There are woodruff keys that fit in this shaft...I think you will have to removed the side cover...chances are they will fall out if you move the shaft. Otherwise that should work. Good Luck
"Better By Design"
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 5:25pm
That's the best way to do it.
