Need help with D17 hydraulics |
Post Reply |
IVD17gal
Bronze Level Joined: 27 Sep 2010 Points: 9 |
Posted: 27 Sep 2010 at 9:02pm |
I have a Series IV D17. The other day I started it up and could hear a high pitched whistle that seemed to be coming from the hydraulics. Tonight we were going to try and figure out what was wrong, I moved the position control lever and the traction booster lever to see if it would make the noise stop, but now there is a loud grinding noise that doesn't stop. The position control lever is now very hard to move and doesn't seem to do anything. The rams are fully extended and will not go down at all.
Any thoughts? |
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9507 |
If you hear a sucking sound coming from your wallet, you know it will be expensive. LOL
How are tractor's fluid levels? |
IVD17gal
Fluids should be ok, but I can't properly check the hydraulic fluid because I can't collapse the rams.
IVD17gal
The noise its making now is the same one you would get if you were using the remotes and kept the lever engaged after the implements cylinder was fully extended or collapsed. Except it wont stop.
Wes (VA)
Orange Level Joined: 12 Sep 2009 Location: Elkton, VA Points: 510 |
Sounds like the traction booster valve sticking.. -Wes
IVD17gal
How do I fix it?
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7379 |
Check that the traction booster linkage is not pushing against the valve on the underside of the console.
IVD17gal
There is a piece that sticks up between the traction booster linkage and the position control linkage that is against the valve.
Gatz in NE
Orange Level Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1040 |
make sure the TB valve spool is not sticking either...
IVD17gal
Your pic is what mine looks like. How do I un-stick it? I don't use the tractor to plow so I don't need the valve to work just to stop making the noise. Would the traction booster valve stop the 3point from going back down?
Gatz in NE
The cap can be removed from the rear of the TB valve, see pic. Squirt some penetrant on the stem and work it back and forth. Might be a bit tedious to do, but if it's hung up, that's what needs to be done.
Again, like others have mentioned, make sure that all the linkages are free and not rusted tight or bound up.
IVD17gal
Thanks, and the only lever that is hard to move is the position control lever.
IVD17gal
Sorry, one more question. Take off the cap that the pic is pointing to or the one below it? Thanks for all your help. Grandpa didn't know what to do so I was at a loss.
TexasAllis
Silver Level Joined: 14 Sep 2009 Location: Texas Points: 396 |
Yes it will.
Gatz in NE
...the one that the arrow is pointing to
IVD17gal
Thanks everyone. Runs like a champ now.
Post Reply | |
