Need help with D17 engine
timsWD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timsWD45 Quote  Post ReplyReply Direct Link To This Post Topic: Need help with D17 engine
    Posted: 17 Jun 2010 at 7:17am
I need to find out the oil filter and capacity for a 4 cyl d17 engine. Can anyone help?
1953 WD45 W/ D17 Engine
Kevin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 7:52am
I use a napa 1101 filter on mine, forget how many quarts of oil..
paulinkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulinkansas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 8:41am
I sort of remember putting 6 quarts of oil into my D17 gas a few months ago after rebuilding the engine.  I remember buying 2 1-gallon containers, and the 2nd container was half full (or half empty) when the proper amount of oil was added.  Add oil to your filter to the point the oil isn't being absorbed by the filter media, and then spin it on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 8:50am
It depends on what D17 you have. I do believe later models had full flow oil system and used a different filter.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 8:56am
6 quarts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote timsWD45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 9:20am
Thanks for the replies.. I'll get 7 quarts (one extra in the garage) of 30w...
Ass for the oil filter.. it doesn't have any numbers and I haven't taken it off.. however.. please see the attached picture if you can identify..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 9:34am
Fram PH-8A or equivalent.
