need help with an Allis chalmers wd |
hopper
Topic: need help with an Allis chalmers wdPosted: 12 Jan 2017 at 5:40am |
i am having problems with my early allis Chalmers wd. i think it is the governor. i have to start it by putting my hand on the carb for the air intake. i got the tractor as a bucket of parts sitting outside and ive gotten it this far so i am making progress on it. i got another radiator from another tractor and it is a pressurized one and it will over heat if i have the cap on sometimes should it be a non pressurized radiator?
hopper
Posted: 12 Jan 2017 at 5:47am |
hopper
Posted: 12 Jan 2017 at 5:49am |
can anyone tell me how to do the photos right i messed the others up.
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3292 |
Posted: 12 Jan 2017 at 6:28am |
Make sure your choke is closing all the way.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
Posted: 12 Jan 2017 at 7:17am |
Make absolutely sure the choke plate is all there. Sometimes the spring loaded flapper valve is g-o-n-e.
Gerald J.
Posted: 12 Jan 2017 at 10:20am |
Set the picture height to 480 and width to 640 when uploading and then they won't be bigger than the screen when the text is a readable size.
Gerald J. |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 12 Jan 2017 at 10:46am |
I'd run a compression test, you might have a blown head gasket.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3086 |
Posted: 12 Jan 2017 at 10:51am |
you should be fine with either a pressurized or non-pressurized radiator. That shouldn't make I overheat. You've been given good advice by great mechanics. Check what they suggested then post back what you find.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 12 Jan 2017 at 12:26pm |
Here ya go............ Posting Pictures on the Forum
and Sending Pictures From Cell Phone to PC There is LOTS of informative and interresting info in here; Forum Support Only - No Tractor Questions |
jkoby
Joined: 26 Aug 2014 Location: New Castle, IN Points: 179 |
Posted: 12 Jan 2017 at 9:20pm |
Could you have your choke rod connected backwards?
We accidentally had the bracket the connected the choke rod to the choke plate flipped 180 degrees. Drove me nuts for a while. I couldn't understand why the tractor would only start with no choke and would require choke to run. |
hopper
Posted: 13 Jan 2017 at 5:24am |
