need help IDing a briggs motor
NATHAN CAIRNS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Topic: need help IDing a briggs motor
    Posted: 08 Oct 2018 at 7:28pm
I found this older briggs horizontal shaft engine hiding in my grandmas hog shed. need some help identifying it       i couldnt read any numbers from it
B212, WD45, B, 912 Hydro
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 7:30pm
does anyone know how to size images lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 7:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 7:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 7:57pm
ACmowerguy View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 9:24pm
With 9 headbolts, its appears to be a model 23 series, could be 23D, 23A, 23FB, etc.  There should be a tag with ID numbers riveted to the front cylinder cover.
HudCo View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2018 at 9:02am
they could be stamped in the top or one of the two sides of the blower housing they can be hard to see with out cleaning with a wet rag will be labeled as model type and code
Alberta Phil View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2018 at 5:16pm
Very similar to the one in my 1961 Allis B1.  Same air cleaner, too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 6:23am
Hmmm ill have to look for that tag.        I just seen it back there one day when we were pulling out the wd45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 7:18pm
Good News guys   i found the tag. i overlooked it at first since it was covered in mouse sh*t and dust. You were right ACMowerguy  Its a 23AFB     What does the AFB stand for?
Edited by NATHAN CAIRNS - 17 Oct 2018 at 7:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 8:59pm
whats the rest of the numbers? theres more there some where close
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 9:04pm
or just google 'B&S 23AFB'.... first hit is the illustrated parts manual in PDF format !!
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2018 at 8:19pm
Ill post a picture of the tag
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2018 at 8:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 9:07pm
was hoping to see if it was sold on a piece of equipment but all i could come up with was the owner and service manual .  3" bore ,3 1/4" stroke ,22.97cu. in.    5.27hp @ 1800 rpm.  9.00 hp @ 3600 rpm  15. 75 ft. lbs torque @ 2400 rpm
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2018 at 8:15am
It's all right there on the page you used to show this image.
 Click PREVIEW, before posting and read the width and height numbers. 800 wide will about fit the page but you have to keep the same ratio between the 2 numbers.
 If my puter wasn't suffering from the cold this morning, I could show the page, pfffftttt!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2018 at 7:41pm
I'll see if i can ask grandma what it was used for.     It has its own tank so maybe it was on a tiller or something of that nature.   Sadly the air filter tube is detached from the carb so who knows whats in there lol.
