Need help identifying
Naterbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Naterbob Quote  Post ReplyReply Direct Link To This Post Topic: Need help identifying
    Posted: 03 May 2018 at 8:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 8:09pm
AC B, you can find the tractor #, in front of the shifter lever, post that, and you can figger out the year it was made.  I say early, cause it has hand brakes...  Welcome to the forum...Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Naterbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 8:13pm
Okay I will locate the number, any idea what they are worth?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 8:19pm
Generally, $500-$2,500, if you ask me. Are you buying or selling?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Naterbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 8:21pm
Buying possibly
B4 9863
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 8:25pm
That makes it the 142nd B built in 1941.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 6:17am
Creston, I think you missed one, I get 143rd. LOL
Ser. 721 would be 1st, 821 w/b 101st, 861 w/b 141st, 862-142nd, 863-143rd.
Gary
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 6:37am
anybody notice the spring under the seat and the brackets running thru the rear fenders?
is that original? Neat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 6:38am
got a picture of the other side?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 6:51am
Interesting set of wheel centers considering the year model,pretty neat rig.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Naterbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 7:15am
I really appreciate everyone help! I’m new to dealing with tractors this old. Thinking of buying this one and cutting my teeth on tractor restoration. I understand these at not worth much restored but it may open the door to bigger and better.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 7:21am
Beware of B's , especially the ones set up to mow it seems they can be assembled from many years models. The rear wheels seem interesting.
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 8:37am
The rear centers were like pictured-5-bolt with center nut on the adjustable front on the very early models.  They are smaller studs than later models. Leon
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 8:53am
Corbin
The seat is from an after-market supplier back in that era.
Could be a 'Monroe'
Gary
Link to Brian Ahart picture
https://www.google.com/search?q=picture+of+'Monroe'+after+market+tractor+seats&tbm=isch&source=iu&ictx=1&fir=vDtQ5H-NklYABM%253A%252C-fSBQUJd3pnlcM%252C_&usg=__jsmPjxiE3d_ZVK0Un3aDREX3Sms%3D&sa=X&ved=2ahUKEwjxqcG7muzaAhVJmeAKHWvJAq8Q9QEwBHoECAAQNA#imgrc=IsFBAtQNAvS0OM:
Edited by Gary - 04 May 2018 at 8:58am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 9:45am
For restoration a shop manual and op manual will be handy. I have a shop manual on line at: http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
and a military B op manual at:
http://geraldj.networkiowa.com/Trees/BMilitary.pdf
http://grandpas-tractor-site.s3.amazonaws.com/manuals/ac
May have an operator's manual for the civilian version.
Gerald J.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 10:13am
Got a board for a foot rest.Some had adapters for a five bolt rear wheel but later ones used the c wheel with adj front axle.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 10:40am
Anyone else notice the metal piping setup for the lower radiator hose.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 2:14pm
Looks like quite a handymans work,
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 8:40am
So is the alternator bracket mounted on the casting boss or drilled and tapped into the block?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 7:42pm
OEM generator bracket was, who knows how this one is...Wink
