Need Help Identifying AC Forklift |
Jeff Z. NY
Topic: Need Help Identifying AC ForkliftPosted: 17 Aug 2010 at 6:45am |
It might mean propane also. Who knows?
Yours looks like it has solid rubber tires. I can't count the number of fork lifts AC had that started with F. There were many. Edited by Jeff Z. NY - 17 Aug 2010 at 6:47am |
SteveFulgoni
Posted: 17 Aug 2010 at 6:40am |
Thank you, that makes sense. This unit is probably 3000LB at 24 inches. I am thinking now that the "P" in "FP" means pneumatic tires and this might be an F30-24. It has a G153 engine. It runs fine. I will change the oil and air filter and normally I would change plugs, points, power wash, etc, but I am wondering if I should leave well enough alone because parts and manuals are hard to find. Anyone have any thoughts on this? Is there a good supplier of tune-up parts for the G153 out there? Thanks!
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 16 Aug 2010 at 8:57pm |
The 24 is the distance at which the load center is calculated. In this case it is 24".
Jeff Z. NY
Posted: 16 Aug 2010 at 3:25pm |
No, I don't know what they mean. The 30 may be short for 3000 lbs lift because the 20-24 has a 2000 lbs lift I believe.
Edited by Jeff Z. NY - 16 Aug 2010 at 3:25pm |
SteveFulgoni
Posted: 16 Aug 2010 at 12:51pm |
Hi Jeff,
Thank you for your reply. I have looked around on the internet trying to find info and the FP series seems to be the closest I can find. Do you know what the 30-24 means? Is that related to lifting capacity or physical dimensions??? Thanks again
Jeff Z. NY
Posted: 16 Aug 2010 at 9:31am |
Looks like it could be an FP 30-24.
SteveFulgoni
Posted: 13 Aug 2010 at 1:37pm |
Hello,
I just aquired an AC forklift and I am trying to ideintify the model number and possibly the year. The S/N is 6231-3000. It is propane powered. I would guess about 3000LB. I have attached two photos. Thank you
