need help ca
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Topic: need help ca
    Posted: 26 Jan 2012 at 12:50pm
 how do i take of the barrings on the front end of a narrow front ca?
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
JeffMOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 3:16pm
From the manual:
To disassemble pedestal and front steering gear, support tractor under torque tube and remove front wheels. Remove cap screws retaining pedestal to front support and remove pedestal. Remove cap screw, washer and shims from top of vertical spindle shaft and pull pinion gear off shaft. Withdraw shaft, bearing cone and oil seal from bottom of housing.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 3:19pm
If you mean the wheel bearings: Pull off the wheels and hubs. the bearings are ball bearings. The inside of the bearings are a tight fit to the spindles and the outside of the bearings run in a race that is pressed into the hub. You may need a puller or a chisel and BFH to take the bearings off the spindles; a chisel and hammer works well to remove the races pressed into the hubs.
Edited by GregLawlerMinn - 26 Jan 2012 at 3:20pm
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 5:25pm
Did you get a CA ?
