Need help 2000 blazer |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Topic: Need help 2000 blazerPosted: 26 Jan 2022 at 12:56am |
Got a Grandson who is kind of in the same boat. Told him I'd give him $$ and all he had to do was...... Haven't seen or heard from him since. Look at what we gotta go through Kenny for 10 minutes of enjoyment.....
Kenny L.
Posted: 17 Jan 2022 at 12:23pm |
Sorry for not getting back quieter but it turn out to be fuel pump and he let the gas tank get so low that it also suck up some dirt or something and now cly 1& 4 are dead so need to replace the spider injectors now, I told him 100 time that he couldn't let the gas get down past a 1/4 tank because the gas kept the fuel pump cool so now he is walking or relying on so friends to get around until he does enough thing for me to earn the money that is need to fix it. I'm hoping it's a life lesson for him. Again thanks for all the comments.
Edited by Kenny L. - 17 Jan 2022 at 12:29pm |
D19allisowner
Posted: 28 Dec 2021 at 4:31pm |
I worked on them back in the day and if they dont have a minimum of 60 pounds of fuel pressure they won't start. Sometimes you could put a battery charger on them to boost the voltage to get them to start but that didn't work all the time.
If you choose not to decide you still have made a choice.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 27 Dec 2021 at 8:03pm |
fuel presure needs to 60 to 66 psi while cranking check for injector pusles , if that checks out move on to the distributer they seem to go to crap on those
kncfsmith
Joined: 27 Aug 2012 Location: Versailles, Oh Points: 24 |
Posted: 27 Dec 2021 at 8:01pm |
check fuel pressure at the fuel rail port changed a lot of fuel pumps on them
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 27 Dec 2021 at 7:42pm |
I would give it a shot of starting fluid. If it sputters or starts then you know it is fuel causing the problem.
1957 WD45 dad's first AC
Joined: 11 Sep 2009 Location: illinois Points: 90921 |
Posted: 27 Dec 2021 at 6:26pm |
WE had a 1998 Explorer that cranked good... good spark.. good fuel.. and would not start... There was a SENSOR at the front of the crank shaft that basically told the spark when to occure... SENSOR was bad..... similar to being OUT OF TIME.
Edited by steve(ill) - 27 Dec 2021 at 6:28pm |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35707 |
Posted: 27 Dec 2021 at 6:08pm |
Delivery of fuel at injectors.
Kenny L.
Posted: 27 Dec 2021 at 5:14pm |
Grandson 2000 chevy blazer willn't start turn over good, has fire at plugs, fuel pump is pumping gas though the filter, fuse test good (I think) it's a 4.3 v6 what am I missing. Thanks
