need electric fuel pump
jeff n View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeff n Quote  Post ReplyReply Direct Link To This Post Topic: need electric fuel pump
    Posted: 10 Apr 2010 at 7:51pm
I need some help i need an electric fuel pump to increase my fuel presser.
I need to increase it 25 to 30 psi. Where can i find one ? any help would be grateful,Thanks.Jeff.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 8:25pm
Only ones I know that put out that pressure are the in-tank type , small pumps I have used have 12 PSI tops that i have seen . In tank require cooling from tank content to have long life.
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 11:13pm
Jeff; Check with your local speed shop, or Summit Racing, Barry Grant, Areomotive, Holley, Mallory, and others have pumps that will work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 7:46am
What's the application? As Brian mentioned, you'll need a racing pump for that kinda of PSI. Just make sure whatever you're feeding is able to handle the pressure. Most carburetors usually will handle 5-6 psi at the fuel bowl. Anymore than that (unless its a big inch Pro Stock engine with a pair of 1100 CFM Dominators)  will have problems. If its a late model automotive F.I. engine most need 30-45 PSI at the fuel rails. For either application, don't forget to install a fuel pressure regulator in the fuel system, and on the electrical side, don't forget to wire in a relay to handle the electrical load of the pump... HTH
Steve@B&B
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 8:37am
most important thing on a fuel pump is volume not pressure. Are you trying to feed a ROOSA that much? I use a HOLLEY 15 psi on my Roosa. Too much feed pressure to a Roosa will spike its transfer pump pressure and seize the head & rotor! be careful, Ed.
thumb farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thumb farmer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 8:23pm
Ed is right if your feeding a rosamaster. I ran a blue holly on our7580 for like 5yrs. without problems. also fed the XT with the same pump set up for pullen.lived forever . never siezed a pump.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 8:26pm
Pro stock motors run 3.5 psi just use two pumps for alot of volume.
