Need diesel engine oil advice |
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1619 |
Topic: Need diesel engine oil advicePosted: 17 Mar 2011 at 6:36pm |
What is good year around engine oil for a 6060 diesel tractor? I've been running SAE 30 like the owners manual says but there is probably more modern formulations out there now, advice?
Larry B
Joined: 11 Sep 2009 Location: charter oak Ia Points: 386 |
Posted: 17 Mar 2011 at 7:13pm |
i have a 7045, dt160, and a jd4440 and use rotella 15-40 in all of them year around
powertech84
Joined: 17 Oct 2009 Location: Wisconsin Points: 487 |
Posted: 17 Mar 2011 at 7:29pm |
I like to use a 5w30 in smaller diesel engines. It helps them crank and start alot easier, especialy in winter. Being from minnesota, and not the southern part of the country, you'd be fine to run it year round.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 17 Mar 2011 at 7:31pm |
15 / 40 Rotella in this area year round in all the off road and on road diesels.
AllisFreak MN
Posted: 19 Mar 2011 at 8:05am |
Thanks.
Brian Jasper co. Ia
Posted: 19 Mar 2011 at 3:10pm |
There is a 10w-30 diesel rated oil that the new Ford built Powerstrokes use.
michaelwis
Posted: 19 Mar 2011 at 3:23pm |
We ran 15/40 in our 6060
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 19 Mar 2011 at 5:02pm |
The Rotella oil is a good choice and, if you don't want to change oil very often, the Mobil 1 turbo diesel 5w-40 oil is another good choice------especially if you start in cold weather.
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_Turbo_Diesel_Truck_5W-40.aspx Edited by 427435 - 19 Mar 2011 at 5:02pm |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
