need an honest opinion on tires
mufflerboltz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Topic: need an honest opinion on tires
    Posted: 09 Jan 2014 at 6:57pm
Will 16.9x34 tires be to much on a wc with a good built 244 ci engine?
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2014 at 7:18pm
wel gearing ground speed book shows 16.9-34 the same ground speed as a 13.6 or 15.5-38.
but has a bigger contact area 229 square inches. My local rules have changed. I might be willing to sell my Shurman Underdrive.
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2014 at 8:48pm
I'd think in 3500 and 4000 lb it would be okay unless the sled is ridiculous.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2014 at 7:13am
Fields, what is the mph for a WC with 16.9x34 running 2000rpm?
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2014 at 9:53am
My unstyled with 13.6 38 at 1850 rpm i got a horn at 4mph off the line in first gear are club runs 3mph so I have to idle down the track a good ways before you open it up too much are fair pull is 4mph that's how I know it will go over 4mph
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2014 at 12:03pm
So it would be just about right for a 4 mph class, sweet that's what I'm shooting for.
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2014 at 6:26am
  My WD runs 5.2 in 1 st gear @ 2000 rpm under no load with full cut 16.9x34. It's impossiable to pull 3, 3.5 mph classes. 4 mph is good at 15 to 1600 rps. the trouble down here on this clay is 244 cid wont come back whe the sled loads the rear wheels and increases traction. We bumped the cid. , now pull, 4, 6  and 8 mph!  That equates to First, second, and Third gears in the 3500, and 4000# classes, after that we back to first gear.
   If you pull on loose tracks that allow for slippage you will be ok, but if you are going to be on tight "power" tracks read my post carefully... Just my honest EXPERINCE, not opinion
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Juiceman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2014 at 8:45am
Cotncrzy.. How heavy do you guys usually pull?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2014 at 12:45pm
Pulled 5500 and run oot of room for weights. Still had power...
This page was generated in 0.075 seconds.
