need an engine!
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Topic: need an engine!
    Posted: 12 Nov 2011 at 4:59pm
Does anyone know where I could locate an engine for a John Deere 644 b loader?
It is a 6cyl turbo I believe 531 ci.
Pete
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 10:35am
Pete, your PM inbox is full.  Thanks, Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 4:34pm
Someone told me that they are buying JD combines with engines that will drop into JD loaders. Just sharing.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 4:54pm
I dont think you have a 531 engine. If its an a or b its probably a 404, the later ones had a 466. If you had a 531 you could tell by the fact it didnt have enough power to get out of its own way and it would have had a ring cast on it where they attatched a chain when used as an anchor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 6:15pm
It is a 644 B, I'm not sure what year it is though. As for th 531 c.i. I was going by a manual I found online. As for the power it has never had much, it's my Father-Inlaws machine and he has never been happy with it. The engine locked up on it the other day but he tried it again yesterday and it started, but might have spun a bearing. I'm not sure if we will be rebuilding it this winter or find a donor as Cat suggested. If you come accross something that would work please let me know.
This is the section of the manual-
 Engine: John Deere turbocharged diesel, vertical 6-cylinder,
valve-in-head, 4-stroke cycle.
Bore and stroke .4.75x5 in. (120.5 mmx127 mm)
Piston displacement. . . . . . . . . . . . . . . . .531 cu. in. (8702 cm3)
Compression ratio 15.8t01
Maximumtorque@ 1500 rpm .' .432Ib-ft (586 Nm) (59.7 kg-m)
NACC or AMA (U.S. Tax) horsepower. . . . . . . . . . . . . . . . . .54.0
Lubrication. . . . . . . . . . . . . . .PressuresystemwIfull-flow filter
Cooling. . . . . Pressurized w/thermostat and controlled bypass
Fan Blower
Air cleaner w/restriction indicator.. . . . . .. ., . . . . .. . . . . . Dry
Electrical system. . . .. .. . ... . . . . ... .. .12-volt wi alternator
Batteries (tWei12 volt) .. . Reserve capacity: 310 minutes each
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 10:02am
I stand corrected, the 644 & 644a had a 404 the 644b had the 531 and everythng from the b on up had the 466, so you are correct that is the engine you have, which is unfortunate becasue its a huge pig and expensive to overhaul. I would look for a 466 out of a junk yard if I was you a better motor and it had the ability to get out of its own way.
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 12:00pm
531's are kinda hard to find, find a combine  404 or 466, but you will probabbly need mounts belhousing etc from another machine that had that engine in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 7:58pm
Thanks for the info guys. We'll have to see what we can figure out.
Pete
