NEED Allis 5020 Rear Rims/Other options |
mnsledboy ![]() Bronze Level ![]() Joined: 09 Sep 2021 Location: SE MN Points: 12 |
![]() ![]() ![]() ![]() ![]() Posted: 19 May 2022 at 12:46pm |
I am badly in need of a set of Allis 5020 Rear rims, mine are rusted out and leaking fluid. I cannot seem to find any, also have looked at Simplicity 9523. Do I have any other options on what will fit?
Better yet, does anyone have any or know of any clean rear rims for an Allis 5020, with or without tires. Will either drive to pickup or arrange shipping. Thanks in advance.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88225 |
do you have the 24 inch AG rims or the 16 inch TURF rims.... what is the bolt pattern ?
I have the turf rims. Here are the pictures of them. I dont know the exact bolt pattern but this is a 1984 2WD
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3093 |
I have rims and tires on a couple 5020 parts tractors.
Any pictures of them handy? Are they clean shape?
Isaac... i dont claim to know anything about the 5020 and i would surely look into Garys rims if they are a direct fit...... I though the rears if AG were 16 inch diameter and 13.6 wide so probably a 12 inch rim........ Some FORDS use the 12 x 16 rim with a 6 bolt pattern and a 4.5 inch pilot hole... you would have to verify the bolt diameter, or possible drill new..... Im sure Gary has a better price.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54287 |
I'm not 100% sure on this, but I think any Japanese built tractor of the same era will have the same rims. Furthermore, I think you can swap out turf rims, to 24" AG rims, its the same bolt pattern. Check your local tractor junkyards...
I have been looking around for a while. No luck
That is good to know, I will have to look into that!
I'll get some measurements,think even some 5020 rims had a different bolt patterns.Kinda odd tractors.Most Japan tractors of different brands the wheels won't interchange.
im4racin ![]() Orange Level ![]() Joined: 12 Jun 2017 Location: Garrison ND Points: 1068 |
the 24” are a different bolt spacing than the kubota. The website above is custom building me a set as I type this. Call and talk to Jon. He will help you and probably can build the 16” if that ford one isn’t correct
Robert, do you know the bolt pattern and center hole diameter for the 5020 ?? Just curious.
That would be great, would be interested in a factory set if you have a set that matches. Send a couple pictures or check on their condition if you can!
I do not. However when the new rims arrive I can measure that stuff. Don't want to take the weights off any more than I have to.
Play Farmer ![]() Orange Level ![]() Joined: 13 Jan 2016 Location: NNY Points: 732 |
Would anyone locally be able to repair yours?
I did one on my D17, ever since I've been doing a few for the local tire guy. ![]() If you were closer I be happy to get yours patched up. |
I wish that was an option, mine are too far gone and fluid has leaked out of the tubes now..
Gary, did you find out anything?
Bullitt 5253 ![]() Bronze Level ![]() Joined: 31 Jan 2023 Location: Hankamer texas Points: 1 |
I have a set of 2050 rear rims with turf tires in good shape
I’ll send you a PM Bullitt
Pferdestärke23 ![]() Bronze Level ![]() ![]() Joined: 07 Jul 2024 Location: Minnesota Points: 37 |
![]() This is the Hinomoto E23 Rear AGRICULTURAL Hub used for the Allis Chalmers 5020. B.C. 6x139.7 Pilot 93.1 Bolts M16x1.5 Hinomoto used a completely different Hub to mount the TURF Rims. [ This Hub is available NEW in Europe. But not any Rims. Go Figure . . . ] Edited by Pferdestärke23 - 24 Jan 2025 at 9:03pm |
Hinomoto made both a Rear AG Hub and a Rear TURF Hub for these tractors: Hinomoto E23 Allis Chalmers 5020 Simplicity 9520 Massey Ferguson 210-4 Hinomoto E25 Presumably the same Hubs were used for the Deutz-Allis 5220 Later on Hinomoto was purchased by Hitachi so presumably the same Hubs were used for the Hitachi NZ235 It's such a shame that Hitachi eventually stopped playing with its new toy . . . Edited by Pferdestärke23 - 24 Jan 2025 at 9:48pm |
SPAM Deleted Edited by Pferdestärke23 - 24 Jan 2025 at 9:54pm |
