Need Advise/Thoughts/Non AC Topic
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Topic: Need Advise/Thoughts/Non AC Topic
    Posted: 16 Jul 2011 at 9:11pm
OK, Here goes. As this problem does not involve AC Equiptment, i understand I may in the wrong Dept with this one. One might say this is a "test" so to speak. It clearly has nothing to do with "Shops/Barns/Varmits+trucks" therefore I chose to post here. My hope here is that only willing/helpful respondies post there thoughts, but i understand I'm up for ridicule again as this is a open forum.
I have a client who has a bird house hung from a tree branch off small chain. it is droping about 6 ft off a limb and is aprx. 6 ft off the ground. the problem is the "house" will not stay in line with her perfered line to view, in other words it is fixing itself on one position [ facing away from her perfered line]. I studied this tonight and tried adding weight o one side/end and other methods to "adjust" the orientation, with no help. The only thing i finally came up with was possibly the way in which the chain was "looped" around the branch vs hanging off a eyelet.
The house must be hanging Plumb, what is causing this fixed position, I will be a someone's good graces if i can solve this problem. Thanks for your thoughts in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 9:16pm
Two strings or chains,  spread wider at the top. If limb runs in direction other than projected  line of sight, a wire bracket may be needed.Actually a wire from limb hinged at correct location could do the job also. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 9:22pm
Thanks Tracy, I wondered about that. the house wants to hang in direction the limb is going, why does the limb direction dictate the direction of hang? Could a eyebolt screwed into limb give the single chain enough pivot to fix our desired orientation?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 9:25pm
Turn one end of the chain 180 degrees or do like Tracy says and hang it from two points
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 10:05pm
Hanging it from two points will eliminate any wind changing the wanted line of sight.A wire rod with loop on each end fastened between two hige points will stop the clocking motion also. HTH Tracy Martin
